Tires Turf tires - traction?
   / Turf tires - traction? #11
You will get plenty of traction with turf tires. They have a bigger contact patch on the ground than AG tires. Yes they are not great in mud. Plowed snow for 3 winters and they will work better than you think.
I completely agree, I have had turf tires on my TC-29 for 9 years now and had not problem with traction, again it may be because they are so wide and they are loaded. They are sure nice on the lawn and yet I have no problem with using the FEL, bush hogging or grading the road.
   / Turf tires - traction? #12
That's great for a race car, on concrete. Not good for a tractor in dirt or wet grass.
Turf tires aren't slicks, they have as much or more tread pattern to them as most off road pickup tires.
This is my third tractor with turfs, I like them for having pretty good traction on most surfaces and for not digging deep holes within the first couple of seconds of having less than adequate traction.
As far as turning my tractor into a mower, I would say that less than 10% of my tractor time involves the RFM. The rest of the time I am digging dirt or playing skidder or doing some other job that popular opinion might say turfs can't do.
Having said all that, tires that suit me perfectly might be the worst thing ever for others. Depends on soil type, snow type, terrain, how heavy or light the tractor and attachements is. You pretty well have to decide for yourself what will be best. The answer could be two sets of tires and wheels.
   / Turf tires - traction? #13
I have two sets of wheels/tires for the 855. Fall through early spring I run R4's. They give acceptable traction in the nasty stuff and don't kill the grass in the overlapping period. Summer months I run turfs allround. I've been known to have turfs up front and R4's in back during the transition period in spring/fall.
One drawback I have encounted is that since the rears are loaded... it's rather heavy work. :)
As long as conditions aren't muddy, I've had really good results using the tractor and FEL with the turfs on. In fact under some conditions they work a bit better for loader work.
   / Turf tires - traction? #14
Unless you have tried both, it is really hard to give an informed opinion. What you "think" is good traction may not turn out so good in comparison to something else once you try it. I would never have tried R4's on my own, but after using them find they work much better than I would have imagined.
   / Turf tires - traction? #15
I wish I had 2 sets of tires....I have Ag's and they are great for the winter but, I wish come April I could just change them out and go with turf's through the summer and fall......ding ding ding ding $$$$$$$$$.:laughing:
No question that you will not have the traction that you get out of your Ag's.
Not to hi-jack the thread but.....How many operators have 2 sets of tires on rims for different seasons.??
I did, but found I never wanted to put the turfs back on after the 1st change. Sold em before they dry rotted.
larry
   / Turf tires - traction? #16
I have loaded turfs and lots of steep hills to mow...and not infrequently I mow in the morning dew...great traction and lots better than the R4s they replaced. In the winter I chain all 4, mostly because of ice on my 1/2 mile uphill driveway. Only once did I have a problem and that was in mud: I uncovered a spring inadvertently. I could have dug a much bigger hole for myself quicker with Ags, but why?...as was pointed out, turfs have a tread much like the AT all-terrain tires you might put on a 4x4 truck ...in fact, I know I can pull my F350 out of conditions in which it was stuck. I would say that, except for the romp in the spring, I have never spun the tires (HST) ...
as for two sets of tires, that's out of the question for me...the loaded rears would require a chain hoist to deal with and dangerous to boot ...and, given their size and cost, if I had to run Ags on my 4330, I'd buy a ZTR to mow with !!
   / Turf tires - traction? #18
I'm a new compact tractor owner, and concluded early in my learnings that one set of tires won't do everything. I'm not even sure 2 sets will, but I bought my tractor with the R-4's, and then scoured around for a used set of turfs, found them with wheels that will fit for $850....seems like a lot of money, just hope it works as well as I think it will: using the turfs for the mowing and the R-4's for most other stuff.
   / Turf tires - traction? #19
I have turfs on my Kubota L3940. I was very happy with thier performance this winter using my 7' front blade and 7' rear blade. For finish mowing and bushogging, I have not slipped a tire in wet grass. FYI, Kubota has 3 sets of turfs, standard, deluxe, and galaxy. The standard turfs are sub par. I have the deluxe, very aggressive and deep tread pattern. The galaxy are for golf course duty. If you see the grand L series brochure, they show the deluxe turfs in thier pictues. Philip.
   / Turf tires - traction? #20
Do you have any pictures of your tractor?
American G-Model Pump Jack (A56438)
American G-Model...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58216)
2023 WRANGLER...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
(10) UNUSED SDLANCH 2.5CMX3M RATCHET STRAPS (A58375)
(10) UNUSED...
UNUSED X-STAR 20' LOADING RAMP (A58375)
UNUSED X-STAR 20'...
CFG Industrial 12EX-ATA Mini Excavator Attachment Set (A57149)
CFG Industrial...
