Tires Turf Tires for YM2000
   / Turf Tires for YM2000 #1
NCShelton
Monroe, LA
Yanmar YM2000
I have a YM2000 with deep lug agriculturial tires. The size marked on the tires are 9.5/9-24, which I think is 9.5x24. What size turf tires will I need to retain the tractor height, and where can I find them?
Norwood Shelton
Monroe, LA
   / Turf Tires for YM2000 #2
You should have 9 inch wide rims that are 24 inches around at the point where the tire rests on the rim. Your tires are 9.5 inches at there widest dimension. You are lucky since there are many tires available for 24inch rims. Do a Google search for Titan tires and you can try fireston/bridgstone/etc also. The search in their agricultural or grounds care section and find tires that use 24" rims and fit on rims about 9" wide (if the tires are meant for 10" wide rims they should still fit well.
Here is a Titan website..go to "torc trac 3" and look at the first tire #485363
Titan site
Here is a firestone option
Firestone turf tire
Another Firestone option
Firestone option 2
Rooster Weathervane (A55853)
Rooster...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
