Turbocharging new L3940 Gutless Pig Tractor
Status
Not open for further replies.
   / Turbocharging new L3940 Gutless Pig Tractor #61
I dont think it matters what forum you post it in, the advise will be the same.
Well I take that back. Instead of advise telling you to trade up to kubota model XXXX, it will be advise telling you to trade up to deere model XXXX
   / Turbocharging new L3940 Gutless Pig Tractor #62
OK ok ok I can screw with the best of you as you screw with MY thread.
Thanks, Fred
Actually, I am disappointed in you. 'Maybe I should post this in the Deere fourm'. Is that really the best you can do?
You have been given excellent advise here, just not enough matter between your ears to absorb it.
Good luck, Philip.
   / Turbocharging new L3940 Gutless Pig Tractor #63
Maybe I should post this in the Deere forum.
Why not, the wrong size tractor is still the wrong size tractor whether it's green, red, blue, orange etc. We own Kubota, John Deere, Massey Ferguson, Case, Kioti...
   / Turbocharging new L3940 Gutless Pig Tractor #64
I think you just pissed on your credibility. Its time we all quite wasting our time on this thread.:talktothehand:
   / Turbocharging new L3940 Gutless Pig Tractor #65
Fred,
Has anyone told you when the tractor bogs, you back off the HST pedal instead of flooring it? I scanned this thread and didn't see it mentioned... maybe I missed it. Your problem sounds exactly like an operator who is using the pedal just like the throttle/accelerator pedal in a car or truck. It's not like that... it's a variable speed transmission... the more you push the pedal, the taller the gear ratio so you get more speed with the same engine rpms, but less pulling power. An L3940 has plenty enough power so you run out of traction long before the engine bogs, but you gotta know how that HST works to use it. By the way, Deere and other brands with HST are also like that.
   / Turbocharging new L3940 Gutless Pig Tractor #66
Yep, pretty much.
   / Turbocharging new L3940 Gutless Pig Tractor #67
Well everyone else has "weighed in", I guess I will. We think nothing of asking manufactures to put 300-400 horsepower engines in our pickup trucks, so that we may pull heavy loads up hills at fast speeds, yet when we buy a tractor with less than 40 horsepower to the wheels we complain when it cannot pull an 8 foot landplane heavily loaded with dirt/gravel up a steep hill? Why is the 3940 a "gutless pig"?.. You have simply sized the tractor and the implement and the terrain wrong. There is nothing wrong with the tractor that a smaller implement would not fix. Going out and attempting to modify a new tractor with a turbo seems seems like the hard way to solve an easy to solve problem. Why not downsize the landplane? You and perhaps the implement dealer made a mistake, it is not going to be that hard to fix it. But if you want to be hardheaded about it, do as you will, it is your tractor, your implement, your property. But I would suggest that thousands of L3940hst owners do not think of their tractors as "gutless pigs", and have sense enough to size implements and tractors and terrain to make for happy experience. There is my 2 cents.
James K0UA
   / Turbocharging new L3940 Gutless Pig Tractor #68
Yep!
Fred,
Grandad my man, I think you just nailed it! Operator error...My L3800 would pull that thing up hill no problem.
   / Turbocharging new L3940 Gutless Pig Tractor #70
The thing I don't believe about this is he running out of power before he runs out of traction.
Status
JMR 72" Root Grapple (A50121)
JMR 72" Root...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
Case IH 1020 Platform (A50514)
Case IH 1020...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
