Tuition - Jim's first real day with Thor
   / Tuition - Jim's first real day with Thor #1
webbmeister
Wauconda, Illinois
New Holland TC25D
Tuition - Jim\'s first real day with Thor
Today I learned that the price for a lesson on where to *not* till is $55, payable to Whitey's towing service. In addition to the fee, there was some good-natured kidding.
Early this morning, I drove out to Valhalla to finish setting up the tiller from Sweet, and promptly began tilling the area that SWMBO had designated. All was going well, and I was pleased not only with the magnificent performance of the tiller, but with the pretty good looking long, graceful arcs I was making around the edge of the area being tilled. Downright artful, if I do say so myself. Each new pass was taking me closer and closer to the pond, but I wasn't worried - the ground all looked the same color, and I had walked near the water before starting, just to be sure. Well, here's something I bet just about everyone on TBN would have though about ... the tractor weights a lot more than the driver! Well, I drove right into the muck, sunk right down to the rims, and started spinning all four wheels with the differential lock engaged. I stopped that quickly, and then - with a certain smugness - I began using the FEL to push myself backwards. Only one problem - I was pushing myself right toward the water, and I couldn't steer. After an hour or so of pulling myself forward and backward with the FEL and getting closer to the water with each pass, I gave in and called my dealer. To his credit, he did not laugh, or even snicker! The wrecker arrived, I endured some ribbing, and 5 minutes later, Thor was on Terra Firma.
Not to be defeated, I finished tilling the part of the designated area I thought was safe, and then pulled the pins on the MMM and mowed Valhalla for the first time. Valhalla looks good! I did run into a problem along the way, though. With just a few passes to go, the MMM threw one of its three blades. That was a shocker - and, I suppose, more evidence of the niggling QC problems at New Holland. I retrieved the blade, the bolt, and the two washers, moved to a flat area, turned off the tractor and put the keys in my pocket. Got the ratchet set out of the nifty toolbox behind Thor's seat, and put the blade back on.
The sun began to get low in the sky, I finished the last of the mowing, and put Thor in his temporary digs for the night. I now have 13 hours of seat time, and I can't wait for the grass to get long again. This in spite of being dog-tired, $55 poorer (but richer by a little wisdom), *filthy*, and chagrined.
Tractoritis. Wow.
Jim
   / Tuition - Jim's first real day with Thor #2
Re: Tuition - Jim\'s first real day with Thor
Thats a cheap price for a learning experience. I hope to have mine in that price range.
PJ
   / Tuition - Jim's first real day with Thor #3
Tractoring ! What a Rush!
   / Tuition - Jim's first real day with Thor #4
Jim. were you tilling with the MMM on your tractor? If so, was it the MMM that was preventing you from successfully self extricating? I know with my NH 1920 with sub frame mounted BH I am very careful about where I go because of the ground clearance issues.
Bill C
   / Tuition - Jim's first real day with Thor #5
Great lessons. More support for always conducting a "pre-flight inspection." I've not had blades come off but I've found loose bolts, incomplete welds, etc on new equipment. When it's your tail in the seat, final QC is up to you.
   / Tuition - Jim's first real day with Thor #6
Jim, I've been in a similar situation where the ground turned to muck where I was tilling and was able to get out by using the tiller to help push, (and 4wd and diff lock). Needless to say that was the last pass for that area until the ground dried out. JJT
   / Tuition - Jim's first real day with Thor #7
With just a few passes to go, the MMM threw one of its three blades. That was a shocker...
Lost a blade! How far did it fly? I'd be all over the dealer's butt on that. Do ya realize what kind of damage that blade could have done if it hit something...or a person?
Yes - it was not a problem at all on solid ground. I could tell, though, that it was contributing to problems in the mud. I do not have a reasonable place to take it off yet - house not yet built.
Thanks,
Jim
"final QC is up to you"
Amen!
I am quickly learning about all the things that should be on that list.
Yes - I tried that too. That mud is now more than ready for planting.
Well Roy, it flew/cartwheeled about 10 feet and stopped. Made quite a racket coming out from under. I can truly imagine the damage it could have done, and thank my lucky stars that I was out there alone when it happened. That way, my only real worries were finding the parts in the grass and thinking of less than polite ways to let the dealer know what happened. I've been somewhat disappointed by the dealer I bought it from - but it was very inexpensive. My local dealer, on the other hand, has been wonderful and a different story altogether.
Jim
   / Tuition - Jim's first real day with Thor #12
I have learned that lesson myself but it is cheaper where I live. There must be 10 tractors within a two mile radius. We just take turns pulling each other out. The guy with the big JD 4WD got called on the most. Now that I have 4WD I expect to move up on the list!
   / Tuition - Jim's first real day with Thor #13
Ditto Tony, I got stuck after 2 hours seat time on my new JD4200. Luck was with me, my neighbor got home shortly after and pulled me out with his tractor. I think I could have gotten out with someone in the 4wd pickup and me on the tractor, but I was flying solo. My only advice - make friends with the neighbors, they're ususally more than happy to help the newcomers.
Bud
   / Tuition - Jim's first real day with Thor #14
Neighbours are great but so is a wife that can handle an ATV. Last week I tried mowing the meadow and got too close to the edge of the creek - no I didn't go in the water but I got into some very soft mud. Four wheel drive didn't get me out. I got the better half to bring the ATV down to meadow, chained it to a tree so that it wouldn't slide and used the winch on the ATV to pull me out. By the time she got the ATV back to the house, I was stuck again. Back down she came and pulled me out again. That was enough for one day so packed it in.
Well, gee! Maybe I shouldn't have been quite so embarrassed! It's beginning to look like it happens to more of us than I thought! Thanks for sharing.
Jim
   / Tuition - Jim's first real day with Thor #16
If you own a tractor and haven't been stuck yet then you really haven't used your tractor!! There are times you just push the throttle all the way up just to see what it'll do. Some times you get the bear, sometimes the bear gets you.
Well, the bear is smacking his lips and wiping the corners of his mouth with a dinner napkin. What's that? Well I'll be darned - he just ordered dessert!
Jim
   / Tuition - Jim's first real day with Thor #18
got my first tractor stuck back around 1954 or so i was only about 12 and dad let me do some plowing, told me to stay away from the swampy area,but i knew better, i could get closer than he said/w3tcompact/icons/frown.gif got the old steel wheeled tractor burried to the axel, had to get my uncle to pull me out with the cat. all dad said ,WAS HE DONE THE SAME THING. just listen next time., since then have managed to get every one of my tactors stuck at one time or another, except this one. but give me time/w3tcompact/icons/grin.gif
   / Tuition - Jim's first real day with Thor #19
First thing I had to do with my L3010 was pull my JD318 out of a hole(I drove it in).
If it were not for abuse my 318 would not recognize me!
I am very glad no one saw that episode!
   / Tuition - Jim's first real day with Thor #20
</font><font color="blue" class="small">( If you own a tractor and haven't been stuck yet then you really haven't used your tractor!! There are times you just push the throttle all the way up just to see what it'll do. Some times you get the bear, sometimes the bear gets you.
== )</font>===== I'm afraid to say i haven't gotten my new tractor stuck for fear i may get stuck if i do say it.
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
