tu2100F questions
/ tu2100F questions #1
ekodish
I recently bought an iseki tu2100f
So far it is working great. I have a couple questions I was hoping you have answeres.
1) What are the PTO speeds (there are three)
2) What size is the PTO
3) How much horsepower does it have. I have seen anything from 17-25hp listed on different sites.
4) I am looking to pull a manure spreader with it. What is the largest size you think i could pull?
thanks
/ tu2100F questions #2
1. 1st=540 2nd=usually around 1200, 3rd is 1 to 1 with engine rpm, I think. You use 1st (540) for post hole diggers, tillers, mowers, etc. Use the other ranges for PTO hydraulic pumps, etc.
2. My Iseki TA210 has the standard 1-3/8, 6 spline, and so should yours.
3. The first 2 digits (21) is the PTO HP. Multiply that times 1.2 to get engine HP (25).
4. I have a customer pulling a Millcreek model 8700 (72 cu ft) with a 21HP Yanmar.
/ tu2100F questions
great response,
thank you
/ tu2100F questions #4
Howdy,
My TL2100F pulls an 8 ft pto spreader like it wasn't there. It also brush hogs better than the Case 430 it replaced. I run a 4ft. brush-hog, but it would run a 5ft. easily. I only use the lowest speed on the pto.
/ tu2100F questions
how many bushels of cubic feet is your 8ft spreader
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
BUSH HOG SM60 DITCH BANK MOWER (A64278)
BUSH HOG SM60...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2000 Caterpillar V300B 30,000lb Rough Terrain Forklift (A64553)
2000 Caterpillar...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
