tu2100F questions
/ tu2100F questions #1
ekodish
I recently bought an iseki tu2100f
So far it is working great. I have a couple questions I was hoping you have answeres.
1) What are the PTO speeds (there are three)
2) What size is the PTO
3) How much horsepower does it have. I have seen anything from 17-25hp listed on different sites.
4) I am looking to pull a manure spreader with it. What is the largest size you think i could pull?
thanks
/ tu2100F questions #2
1. 1st=540 2nd=usually around 1200, 3rd is 1 to 1 with engine rpm, I think. You use 1st (540) for post hole diggers, tillers, mowers, etc. Use the other ranges for PTO hydraulic pumps, etc.
2. My Iseki TA210 has the standard 1-3/8, 6 spline, and so should yours.
3. The first 2 digits (21) is the PTO HP. Multiply that times 1.2 to get engine HP (25).
4. I have a customer pulling a Millcreek model 8700 (72 cu ft) with a 21HP Yanmar.
/ tu2100F questions
great response,
thank you
/ tu2100F questions #4
Howdy,
My TL2100F pulls an 8 ft pto spreader like it wasn't there. It also brush hogs better than the Case 430 it replaced. I run a 4ft. brush-hog, but it would run a 5ft. easily. I only use the lowest speed on the pto.
/ tu2100F questions
how many bushels of cubic feet is your 8ft spreader
24" X 84" METAL SHELVES (A63745)
24" X 84" METAL...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
Lucknow 360 Feed Wagon (A63118)
Lucknow 360 Feed...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
