Posthole Digger TSC post hole digger
/ TSC post hole digger #1
Alaskanjdeere
Wasilla Alaska
SCOTTS 2554 & JD 4410, x744
Want to know what you think about it? They're asking $349.00 on there web site. Is it worth looking at or should I buy something different? I'll be using it on a JD4410 in soft dirt(SHOULD be no big rocks)
Thanks Shawn
/ TSC post hole digger #2
I have the JD4300 and I baught the tsc post hole digger. It isn't a complex piece of equipement and it did an excelent job on about 30 post. I would buy it again. If you are going to use it proffetionaly and dig like 10000 plus post, you may want to buck up.
Yes, The dealer quoted me @ $775.00 for the frontier phd200 with 9" auger.
/ TSC post hole digger #5
</font><font color="blue" class="small">( They're asking $349.00 on there web site. )</font>
Shawn,
That price at TSC may not include the auger. You may want to check that out.
Augers are an additional $110 or so depending on size.
Last year I got a Speeco PHD on sale at TSC for around $420 with 12" auger.
/ TSC post hole digger #6
I've got the TSC Speeco PHD with 9" and 12" bits. Been through about 100 holes with it last year, and used it on 2 different tractors. I have absolutely no complaints, it has dug through sand, loam and clay without problems. I have not tried rocky soil, and I really hope that I don't ever find that on my property.
For a homeowner working on his own property it is built heavy enough, but I think if I was a commercial user (contractor, fence installer, landscaper) I would pony up the big buck an buy a heavy duty unit.
/ TSC post hole digger #7
I've got one from there with a 9" & 12" augers. I've only done 50 or so holes and am quite satisfied with it. I haven't used it yet on my newer tractor, the TC18, but we'll see in a few weeks how it does.
/ TSC post hole digger #8
I'd be interested to hear from some folks who have rocky soil... what do you use? I need a post hole digger, but man oh man have I got the rocky stuff around. /forums/images/graemlins/shocked.gif
Thanks,
/ TSC post hole digger #9
Alaskanjdeere, I am looking for the same thing and also live in Alaska (Wasilla). I get the same sort of estimates from local tractors dealers, mostly around $1,000 to $1200. When I have priced PHD's from the lower 48 it sounds great until I get around to the shipping costs. Got any suggestions to lower that part of the equation??
Thanks for all the reply's I think I pick one up when I'm driving thru Billings MT.
LateBloomer I'm also in Wasilla just ordered my JD4410 package out of lees summit Missouri Saved $10,000 (Craig Taylor would not budge on quote) I'm driving down in May to get it.
Shawn
/ TSC post hole digger #11
I bought a used TSC post hole digger from Centex, who posts on this board. It came with the 6", 9", and 12" augers. I have pretty darn rocky soil, basically fractured limestone interspersed with clay.
The 12" auger does just fine in dirt, but when you get in gravel, the shear bolt will pop pretty easy. I used the 9" for the first time about 10 days ago and it digs much better. Less torque on the cutting flutes I guess. Dug 12 holes in really rocky stuff with no shear bolt replacement.
I don't think the TSC digger would work in really rocky soil, particularly gravel/cobble larger than 2" in diameter.
/ TSC post hole digger #12
Thanks for the advice - I do have rocky soil like you describe, and I think it might be too much for a lighter duty post hole digger. Where I'm working now it seems like 50-50 between good size rocks and soil.
/ TSC post hole digger #13
I, like Steve, would be interested in knowing what people sugggest for rocky soil. I was looking to use a PHD for planting trees and bushes, but I am thinking I need a backhoe. I would much prefer the PHD... /forums/images/graemlins/smile.gif
/ TSC post hole digger #14
</font><font color="blue" class="small">( knowing what people sugggest for rocky soil )</font>
The problem is "rocky soil" is not a very well defined term. What works well in one piece of rocky soil may not work at all in another piece of rocky soil. I have 20 acres of rocky soil but the nature of the soil and rocks varies drastically over the land. A lot depends on the type of soil that the rocks are in. If the soil is loose and sandy, almost any auger would probably work well but if the soil is heavy clay you may have to get some heavy duty equipment. Even medium soils can pose a problem if you hit a large rock that is only partially in the hole. For solid rock, you would need to spend around $5000 plus the cost of adding hydraulic outlets on your tractor. The best information you can get would come from people who have actually dug in your area; i.e., fence builders and their suppliers. If you get it wrong, it can be very expensive as I learned the hard way.
For planting trees and shrubs, I would go for a backhoe instead of a 3PT PHD as it would be much more useful. I have a lot of implements for my tractor and I find that I use the backhoe far more than anything else. I have just about forgotten how to use a shovel. It is refreshing to go out and dig a hole or dig up a stump and not even work up a sweat. Of course for the price of a backhoe you could buy a PHD that would dig holes in solid granite or several lesser PHDs.
If you are going to go with a PHD, you first need to find out what kind of auger is required for your particular soil conditions and then buy a PHD that can handle the augers you get. When you buy the auger(s) be sure you can easily get replacement teeth for them at a reasonable price. One thing I found with rocks is that shear pins in the drive shaft can be very frustrating. I would go with a clutch option if offered with the PHD or you could possibly find yourself spending a lot of time replacing broken shear pins. I passed on this option when I upgraded my PHD and then found that it was too expensive to add on later. Another but more expensive option is a hydraulic auger which gets rid of the drive shaft altogether.
/ TSC post hole digger #15
sounds like a good buy. i was quoted a JD post digger for 876.00 brand new. I am thinking of buying it but i have seen cheaper other brands out there and considered buying unless i am going to use a lot.
1999 INTERNATIONAL (INOPERABLE) 4900 (A67714)
1999 INTERNATIONAL...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
CASE  721F WHEEL LOADER (INOPERABLE) (A67714)
CASE 721F WHEEL...
Kubota L175 Tractor (A62613)
Kubota L175...
2005 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2005 Hypac C530AH...
2019 Nissan Sentra Sedan (A66738)
2019 Nissan Sentra...
