TS2810F
/ TS2810F #1
bareboatin
Hi Guys, I have a TS2810F . It has a Isuzu engine with the number 28 label.
When the breather cap is on , oil will blow out thru the breater cap. I claeaned the breather cap but it did not help it any. My first thought is blow back pressure because wear in the engine 1,321 hrs. I can run it without the breather cap and it does not blow any oil out. Another thing..When I add oil it goes in very slowly and air bubbles come up and the oil flows in faster when this happens. I think the engine crankcase ventilation is obsturcted, thus the air bubble ? I have not been able to find a repair or parts manual for this tractor . Any help would be appreciated. Thanks Chuck
/ TS2810F #2
I can supply you with a parts book & the closest repair manual.
/ TS2810F
I'm not sure if this is the correct way to add info but ...I dont think this tractor has an Isuzu engine . Its a 3cyl and I assume it is made by iSEKI?
I have discovered that the air filter is dirty and this seems to be causing the oil blow back problem. Adding oil problem being slow ? Stil does it but I dont know why. I cleaned the air filter and then left the metal end cap off and it seems to have corrected the oil blow back. I need to find a source for a new air filter. In addition I need the fuel filter. The oil filter is a Napa 1512 or at least thats whats on it now. Does anyone have a cross reference list for Napa or other auto parts ? This is a great tractor but man parts are a *****. I will contact Sheafers . Tks for the info. Chuck
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
