Trying to build a 42" Rotatary Mower
/ Trying to build a 42" Rotatary Mower #1
FlyC17s
Hattiesburg, MS
Kubotal KX 91 and L3800
Would please like some engineering help.
I have a Kubota KX 91 mini excavator that has a aux pump that puts out 10.9 GPM. I want to build a rotatary mower that uses a hyd motor that turns a single 42" blade. Was told I need to have a motor that puts out 3000 rpm at the shaft and turns the blade (at the tip, 15,000 Ft/Min) Am trying to cut heavy briars, stuff up to 1" thick.
I can build the deck and fasten the new deck to the mini. Just do not know what size hyd. motor to get to push the 42" blade. Can someone offer advice? Thanks
/ Trying to build a 42" Rotatary Mower #2
Basicily you take your GPM and size it to the RPM you need,
for some reason that seems a little fast to me, as even the smaller lawn mower at 30" is only 3400 to 3600 RPM using a standard engine,
I would suggest swinging blades for cutting that heavy of product,
two ways of doing it direct or nearly direct possibly a arbor that is driven directly by the HYD, motor, and the second is to use a standard mower gear box and drive that with a HYD motor,
possibly using a kit or parts Build Your Own 5' Medium Duty Rotary Cutter Kit Just Mount to Your Deck | eBay
/ Trying to build a 42" Rotatary Mower #3
for 15000 FPM at 42 inch diameter you would need 1364 RPM at the shaft.
Tip speed in FPM = RPM x 3.14 x diameter (in feet)
The safety police recommend 19000 FPM as the max tip speed for lawn mowers so that might be good for a brush cutter too, that would require 1728 RPM
Thank you for the insight and suggestions.
If I built a mower something like your saying, how do i find out what type of check valves, safety valves, by pass / pressure relief valves and everthing else that goes in between the hyd motor and the auxilary line to the machine?
Thanks for any help.
/ Trying to build a 42" Rotatary Mower #7
Hey flyc17s, Check out this link to Surplus Center. They have all of the hydraulic components you need and gear boxes too. This link takes you to the HYD motor calculator that might help answer your questions. I am looking at building a brush mower to go on my skid steer and have spent a good deal of time on the surplus center site.
Surplus Center
Good luck with your project
Tim
Thanks for the help. Great site to look at to get some even better ideas.
Surplus Center was a very interesting site to view. When time permits I will spend more time here.
Thanks,
Peyton
/ Trying to build a 42" Rotatary Mower #10
Are you a crewman on the C17?
/ Trying to build a 42" Rotatary Mower #11
FlyC17s ,
I really don't you have enough juice to run a 42 in blade with enough torque to do a credible job.
For example.
Using your 11 GPM, and maybe a 3 cu in motor, that will power the hyd motor to about 847 rpm.
Now, as far as the torque. 3 cu in, and 3000 psi, will provide about 1433 in lbs, or 120 ft lbs
If you go with a smaller cu in motor, you decrease the torque, but gain rpm.
/ Trying to build a 42" Rotatary Mower #12
FlyC17s,
If you stick with the 3000 rpm, , and 11 GPM, the cu in of the hyd motor would be about .847.
The torque using .847 cu in and 3000 psi = 405 in lbs or 44 ft lbs.
Here are some pic of a hyd blade attachment. Don't know all the particulars.
/ Trying to build a 42" Rotatary Mower #13
J.J, what kind of torque should we be looking for for an application like this. 42" blade? 72" blade? Or does the blade length even matter? It seems like I saw a torque spec that some manufacturer published for a brushcutter but I can't seem to find it.
Tim
/ Trying to build a 42" Rotatary Mower #14
General rule of thumb is 5hp/foot, so you would need ~17.5 HP to drive it. Hydraulics are ~80% efficient, so you would need to start with ~22HP used on the engine to get ~17.5HP at the deck.
Aaron Z
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2019 Ford F-350 (A55973)
2019 Ford F-350...
CASE TR310 SKID STEER (A60429)
CASE TR310 SKID...
BUNDLE OF 20' UNION STRUTS (A60432)
BUNDLE OF 20'...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
