Truck wiring questions
   / Truck wiring questions #1
ScottAR
Greene Co, Arkansas
JD 1050 2wd, Case 580D 2wd
The vehicle is a '99 F350 with original tow package. There's a factory square plug for the original tow package 7 wire RV plug (missing). Someone added a 7
wire plug in the bed for a gooseneck hitch. What I want to do is retain the bed 7wire, and add another 7wire to the bumper without cutting off the square plug.
Is there a factory adapter I can Tee out two 7 wire plugs or is surgery in order?
I should be able to figure this out but I'm stuck.
   / Truck wiring questions #2
If I understand, you want to have both 7-pin plugs in the bed and on the bumper working.
They make a TEE connector that plugs into the truck harness and the existing bumper connector plugs into it. It comes with a pigtail that you can run to the bed. I think I've used ones from Hoppy or Pollak but any good trailer supplier should be able to get them.
   / Truck wiring questions #3
Yes, Uhaul or any trailer hitch shop will have what you need that will go in with no cutting of the wires. I have even seen what you need at most large Super Wal Marts. That is if the previous owner did not butcher it.
Chris
Valley seems to make the one I need... Thanks guys...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
