Truck wiring questions
   / Truck wiring questions #1
ScottAR
Greene Co, Arkansas
JD 1050 2wd, Case 580D 2wd
The vehicle is a '99 F350 with original tow package. There's a factory square plug for the original tow package 7 wire RV plug (missing). Someone added a 7
wire plug in the bed for a gooseneck hitch. What I want to do is retain the bed 7wire, and add another 7wire to the bumper without cutting off the square plug.
Is there a factory adapter I can Tee out two 7 wire plugs or is surgery in order?
I should be able to figure this out but I'm stuck.
   / Truck wiring questions #2
If I understand, you want to have both 7-pin plugs in the bed and on the bumper working.
They make a TEE connector that plugs into the truck harness and the existing bumper connector plugs into it. It comes with a pigtail that you can run to the bed. I think I've used ones from Hoppy or Pollak but any good trailer supplier should be able to get them.
   / Truck wiring questions #3
Yes, Uhaul or any trailer hitch shop will have what you need that will go in with no cutting of the wires. I have even seen what you need at most large Super Wal Marts. That is if the previous owner did not butcher it.
Chris
Valley seems to make the one I need... Thanks guys...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
JOHN DEERE 8R 280...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
Electric Concrete Mixer (A51573)
Electric Concrete...
