truck question
/ truck question #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
i have a rental truck they gave me to use while my car is getting repaired . i love this truck it's a dodge ram big horn . now comes the question this thing has 20"tires on it and my mechanic buddy looked at the rearend and he said it has to be a 3/4 ton or better . the thing is it has a 4.7 liter v8 in it and as for as i can see it's a 1/2 ton. but this thing has more power than any half ton i ever drove . so what is it a 1/2 ton or a 3/4 ton? i can post pictures of it if needed. the reason i'm asking is i am interested in possibly buying one just like it if not this one.but i would like a 3/4 ton .
/ truck question #3
Probably a 1500 with a 9.25 rear end,.. most likely a 3.92 gear ratio,..
If it has an IFS suspension up front its a 1500,.. if it has a solid axle it will be a 2500.
/ truck question
well i tried lookin the numbers up but they ain't matching here's the vin number(1D7HA18N28S537138) it has a "D" where there should be a "B" for dodge
/ truck question #5
The easiest way that I know, is to look at the wheel bolt pattern and count the studs, 8 studs = 3/4 or 1 ton, less = 1/2 ton, unless we are talking about late 80`s to early 90`s chev fullsize, where this does not always apply
/ truck question #6
I love my Dodge. Look on the driver door and see what the carrying capacities are, etc.
D.
/ truck question #7
It should be right on the outside doors. If it just says RAM its a 1500 if it has 2500 or 3500 its a 3/4 or 1 ton.
/ truck question #8
Not on a 2008 1500/2500 gas,.. it only says RAM
I'm I invisible or WHAT,.. read my post.
/ truck question
thats the first place me and my buddy looked and they didn't say anything about 1/2--3/4 or 1 ton alli know is this truck is nice it has all the options it even has a rear power sliding window. and it has engine power that is out of this world. this truck made me a dodge believer for sure. i'll post some pictures of it tomorrow.
/ truck question #11
Tommy,
My friend has purchased a Dodge Mega Cab last year, it's a half-ton, and it has eight lugs on the wheels of his truck. We thought at first when we got his truck home they given him a 3/4 ton, but we looked it up on the net, and some of the Heavy Duty 1/2 ton trucks of Dodge has eight hole bud wheels.
/ truck question #12
According to the Dodge website that engine is available in a 1/2 ton only.
D.
/ truck question #13
Tommy,if you like that 2008 dodge wait until you see the 2009 dodge 1500(1/2ton)trucks.The 2009 will have a Hemi(390hp)engine with highway mileage figures at 23mpg.I have a 2004 dodge quad cab 4X4 2500 3/4 ton with the 5.9 cummins diesel that I hopped up the horsepower to around 400hp.Best dang truck I every owned.coobie
/ truck question
i been lookin them dodge trucks up an i too found out that the engine in this one only comes in a 1/2 ton . i hear alot about them cummins engines and the power they have .i put this truck next to my dads 08, ford 150 stx and it dwarfs it. he has i think 16 " wheels and the dodge has 20"when i lean againt his bed the top of the bed is about at my lower chest when i lean on the dodge it's right at my chin.
/ truck question
here are some pictures i took sorry i didn't get one of the outside i'll do thast later when i get back from the dentist(tooth getting cut out). you can notice it has a radiator for just about everything from engine coolant/transmission/engine oil/a/c/ . the brake rotors are the same size as the tires on my chevy aveo.
/ truck question #16
Tommy, it's a 1/2 ton and likely the last of a dying breed. Fuel prices have the automakers in a complete and total panic to make econo-boxes. The specs on several half tons, like the one you describe, exceed those of older 3/4 ton pickups made in the 80's. It seems that many people don't want to own a "heavy duty" pickup so they will only buy a half ton model. However, these same people constantly want the truck to do more and more. Remember seeing the "heavy half" pickups? Other than some suspension items, much of the difference between the half ton and 3/4 ton are likely just in the brakes.
/ truck question #17
I love my Dodge Ram 3500. Here is a pic of it ready to go.
D.
/ truck question #18
Not even close!
Heavier springs, suspension parts, axles, U-joints, drive shaft, transmission, cooling, etc.
Basically, the body may be the same, but the "suff" under it is way different.
Park a 1/2 next to a 3/4 and crawl up under there for a gander. It's obvious when side by side.
/ truck question #19
john_bud said:
Not even close!
I've never owned a 3/4 ton; only 1/2 ton vehicles and 1 ton vehicles. However, I know it is an undisputed fact that some of today's 1/2 ton vehicles out-spec 3/4 ton vehicles of the late 70's and 80's.
I thought the frames were the same between the 3/4 ton and 1 ton pickups until I changed the oil in a 3/4 ton pickup for a friend. Same brand of pickup, far different frame. Maybe it's like comparing the underside of the tandem axle dump truck I had to a one ton pickup; no comparison. I just knew by looking at the rear axle and suspension that the pickup Tommy pictured was a half ton.
/ truck question
after everything i checked out on it it sure is a half ton in a 3/4 ton body. lol. it's the beafiest 1/2 ton i ever seen my buddy who is a die hard chevy man even is impressed after lookin at it. he's even thinkin of switchin over to the dodges after the inspection. just a figure of speach that the truck is a 1/2 ton in a 3/4 ton body . although it is built tough.. i'm gonn hate to bring this thing back to enterprise when my little green bug is finished.
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A61165)
2022 Ram 3500...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
John Deere 74in Bucket with Bolt on Cutting Edge Skid Steer Attachment (A61567)
John Deere 74in...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59909)
2020 INTERNATIONAL...
