truck advice
/ truck advice
I'm still working on selling the camper van we no longer use before we start seriously looking at trucks. We'll test drive a 3/4 as it's been a long time since I have driven one. I wish that the sum total of the advice was all of the same opinion but that's what happens when you ask a question on the internet.
I'm not going to get a Cummins dlesel Dodge, so could we take that argument elsewhere?
/ truck advice #73
If you approach the test driving open minded, you may be surprised at the comfort leval and drivability of some later model 3/4 ton trucks. Good luck in your search.
It is quite unfortunate that the squabbling has clogged your thread, it adds nothing of value to you.
/ truck advice #74
Keep another thing in mind, a 3/4 ton will seem to ride better when towing. The tongue weight will actually make the truck ride and handle better.
/ truck advice #75
Unless you are able to get a newer Ram with the rear air ride but those are new enough that the used market might be a bit sparse.
I will say that GM probably has the best unloaded ride for a 3/4 but dropping the rear tire peessure down helps aby of them.
On my 3/4 the unloaded rear tire pressure is 45 and loaded is 70psi.
Huge difference in ride quality!
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2014 F-150 STX (A56438)
2014 F-150 STX...
