truck advice
/ truck advice #61
I'll bet it's leaked into the transmission bell house and you don't even know. I'll bet it drips too. It's a design flaw in the engine. Two main reasons a RMS will fail, failed bearing on crankshaft, warped crank.
Ive been in the auto/light truck repair industry for 23 years. I have to disagree with your statement. While a failed crank bearing and a warped crank will cause a seal failure, They are not the main reason.
The most common causes for crank seal (or any engine seals) is time and heat. Oil rots rubber. Over time, with all the heat cycles, the seals become less flexible and eventually turn hard and brittle. They can even shrink to the point of falling out of their seats.
Any engine, from any manufacturer will experience this. Typically seen once a vehicle reaches 10 years old or 100 - 150,000 miles.
The only way to avoid major engine damage is to inspect your vehicle at typical maintenance intervals and repair oil leaks upon noticing them.
Problem is.......most people see a leak and just deal with it adding oil as necessary. Well eventually the seal will come out on its own and oil will rapidly flow out of the engine. Then a catastrophic failure happens.
This issue will be "normal" until a new sealing material is developed.
/ truck advice #62
When looking at GM trucks with the 6 speed automatic, I recommend the 4.10 gears (not the more common 3.73). You will actually get better fuel mileage and never notice any downside.
If you are looking at older trucks with 4 speed auto, 3.73 will get better mileage.
The 6 speed has double over drive and at normal highway speeds, you are still around 2000rpms in 6th gear.
/ truck advice #63
Would you have put a clutch in without changing the seal? We all know you don't like Cummins, or cummings. Millions of us have used them in pickups, trucks, tractors, and other equipment with excellent service. To each his own.
My back ground and experience with Cummins is in boats over thirty years. They were always the worst. Cat, MTU, Perkins, westerbeke, paxman, Detroit, Yanmar, all were better, more reliable. Westerbeke is a diesel you start up and never shut down, they are spectacular.
/ truck advice #64
Not to get into the mess of this--But, I am not and probably will never be a Dodge guy. However, There are a ton of Dodge diesels around here and I have never heard of an engine failure for any reason beyond those that just mercelessly beat the begebbers out of their trucks...And even then the failure rate was very low...Front suspension parts and body rot, well, that's another story.
/ truck advice #65
So if the OP was looking for a boat, your experience might mean something. Your bashing of Cummins is almost to the point of being over the top. You've posted a couple of things from internet forums, none of which seem to have a lot of feedback in any of the threads to back up your statement. The last link you posted was someone with a brand new truck, one reply and the OP never came back with any more feed back. We get it, you don't like Cummins.
I'm just hoping the OP of this thread got some usefull info out of it before it degraded into a Cummins bashing, Cummins defending thread.
Back to the topic at hand.
/ truck advice #66
So if the OP was looking for a boat, your experience might mean something. Your bashing of Cummins is almost to the point of being over the top. You've posted a couple of things from internet forums, none of which seem to have a lot of feedback in any of the threads to back up your statement. The last link you posted was someone with a brand new truck, one reply and the OP never came back with any more feed back. We get it, you don't like Cummins. I'm just hoping the OP of this thread got some usefull info out of it before it degraded into a Cummins bashing, Cummins defending thread. Back to the topic at hand.
The more information you have to help make a your choice the better... Been two Dodge Ram diesels in family (my son) a 2500 4x4 2012 diesel, it was recalled for safety issue in steering not repairable, dodge was forced to buy back, second one was purchased a 2015 3500 4x4 diesel and it had a RMS failure at 40k. That's my Dodge Ram experience, thought you might want to know.... In total that's about $125k of junk.... Not impressed.
/ truck advice #67
Funny chit..Your story go with it.LOL.Typical Dodge ram hater.laffin.
/ truck advice #68
TBN has a resident troll. :laughing:
/ truck advice #69
We didn't have much need of a boat in the oil patch. My boss had a party barge that we'd take to the lake and it was a lot of fun. But, other than building a raft when I was twelve, that's my boat experience. To use a bad pun, "Whatever floats your boat!"
/ truck advice #70
Sounds like your Diesel engine experiences is very limited and short.
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
