Troybuilt Sickle bar mower
/ Troybuilt Sickle bar mower #1
sos1
It cuts about 1/2 grass and just knocks down the other 1/2.
I don't understand. HELP
/ Troybuilt Sickle bar mower #2
It's a guess, but I'd say that there's too much clearance between the cutters and the fixed bar. Can you post photos of the grass not cut? Photos of the cutter assembly? Is the uncut grass always in the same place in relation to the cutter bar?
I'll check
/ Troybuilt Sickle bar mower #4
I agree with Gary. Has anyone used a walk-behind sickle mower that worked? I've tried (not owned) Troy-bilt, Jari, Gravely, none worked worth a darn. Sharp or not, tight or not. Too bad since one would be useful here.
Jim
/ Troybuilt Sickle bar mower #5
I've had 2 Jaris which do a pretty good job of mowing but rattle themselves loose with frequency.
/ Troybuilt Sickle bar mower #6
Lawn with 4 inch high grass, or field with 4 foot high grass?
Sickle bars aren't lawn mowers.
Bruce
/ Troybuilt Sickle bar mower #7
That's true, they work best when the grass is tall and not too fine. Then the stems resist the forward pressure of the cutter bar long enough for the sections to cut em. No good on lawns or fine grass. YMMV
Jim
/ Troybuilt Sickle bar mower #8
I used a Jari as a kid and it worked fine. You sometimes had to pound down the supports that held the moving cutters as they would loosen up. A 3 lb hammer worked well. It was used for tall grass about 3 times a summer. I think we had a National as well which was a nicer sickle bar mower
The best is BCS and it is expensive but it really works.
/ Troybuilt Sickle bar mower #9
We had several of these mowers at work and used them for many years. The sickle bars kept breaking on every machine. That is the only problem we had with them. Probably why Troy-Built does not make them any more and replacement bars are no longer available.
/ Troybuilt Sickle bar mower #10
I have a Troy built model also and it cuts weeds and brush great but does not cut grass well even if adjusted properly. There are two adjustments on the top bar that adjusts the clearance between the fixed lower bar and the moving top cutters. Each adjustment has 3 bolts, loosen the outside 2 bolts and then the clearance is adjusted with the center bolt. Make both sides match and then lock the outside bolts back down.
New/Unused Electric Winch (A65583)
New/Unused...
Bestway 750 Sprayer (A66285)
Bestway 750...
2022 EZ-GO ELITE...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2006 International 9400 Semi (A66285)
2006 International...
