Trouble Shooting "Low" Operating Temperature
/ Trouble Shooting "Low" Operating Temperature #1
Smalljobs
Massachusetts
Jinma 284
There are some excellent threads on this and they all helped me. I think it might be helpful to others if I post my own situation. The machine now has 100 hrs and the gage always read low on the first mark off the pin. I removed the thermostat and found it to be conventional and unlike others that have the well documented vent/bypass problem. The OD fits into a shallow counterbore inside the lower housing while the upper housing clamped it in securely. The factory stat was marked 75C. I bought a new Stant PN 45358 rated at 82C and put them both in a sauce pan and checked with a digital thermometer. All worked as expected.
Based on threads by others, I measure the resistance on the sensor and found it to be .79 ohm from the lead to the case. Resistance from case to block was near zero.
Then I removed the radiator cap and put cardboard in front of the radiator.
When the radiator coolant reached 52C/125F, resistance was .04 ohms (tractor off, key off) but the gage was still on that first mark.
At a measured 75C/167F in the top of the radiator, sensor resistance was .05 but the gage was still at that first mark. I also removed the lead from the sensor, found it to be bright and clean and cleaned it again with no improvement.
At this point, I'm not sure if I have a sensor or gage problem and am working my dealer to solve it. I'll post the solution when we solve it.
/ Trouble Shooting "Low" Operating Temperature #2
Have you replaced the OE pressure cap? Because a common mistake is simply to buy one that fits - rather than buy one that matches the correct pressure release point. Most of the time it's probably a 15 pounder. The Jinma 200 Series - at least the ones I've either owned or worked on - use a VERY low pressure cap. The metric equivalent is about 4.3 psi. There are very VERY few American aftermarket caps (that fit) in this range, so about the best one can do is a 7 pounder.
If you're still using the OE cap, this probably won't help. But if you've gone aftermarket - your test results may have been skewed by the cap you're using.
//greg//
Greg - tks. The cap is OE. My coolant temperature readings were with the cap off and a digital meat thermometer immersed in the top of the radiator.
/ Trouble Shooting "Low" Operating Temperature #4
//greg//
The cap pressure wont be a factor with coolant temps so far below 100C. However, the use of a low pressure cap on oem suggests that they run cool normally, and so dont need much pressure to prevent boiling. Could be the system cant stand much pressure - so caution is good.
larry
/ Trouble Shooting "Low" Operating Temperature #5
The sending unit is a thermistor. As coolant temps rise and fall, resistance falls and rises. A cold engine will be cause max resistance, a hot engine will cause minimum. So to test whether your problem is the sender or the gauge, simulate a hot engine. That is, no resistance.
Remove the wire from the sending unit, turn the keyswitch to the ON position. Watch the gauge, and briefly ground the wire to the block. If the needle pegs, the meter's good - replace the sending unit. If the needle does the same old thing, replace the gauge.
Disagree - the wrong pressure cap can skew gauge indications because it causes leakage elsewhere in the system. But since OP is still using an OE cap, the point is moot.
//greg//
/ Trouble Shooting "Low" Operating Temperature #6
Temps in the top of the radiator arent always the same as engine temps.Even with rad blocked,you will get cooler than actual readings in the top of rad.Esp true if the t stat isnt fully opening.
/ Trouble Shooting "Low" Operating Temperature #7
Disagree - [[[the wrong pressure cap can skew gauge indications because it causes leakage elsewhere in the system.]]] But since OP is still using an OE cap, the point is moot.
//greg//
What do you mean? Leakage from the system or within the system?
larry
Greg - Tks, will try that tomorrow and post. Bolton Power recommended the same approach.
/ Trouble Shooting "Low" Operating Temperature #9
larry
I don't know the technical reason that manufacturers increased cooling system pressures over the years. But 4 PSI systems were common in years past. See RADIATOR 4 pound Pressure Cap - Wayne WR-5 New Old Stock #2. And we all know that much of the engineering in these Chinese tractors dates back many years as well.
So on this Jinma, we're talking quite low coolant system pressure - about 4.3 PSI. The pressure that pushes against the relief spring in the cap is the same as that which pushes against all the seams, hoses, fasteners, seals, and gaskets. I've seen a 15 PSI pressure cap on a 200 Series Jinma cause hot coolant weep profusely; underneath hose clamps, through radiator tank crimps, past sending unit threads. Stop them, and it starts pushing on the pump seal.
As I'm sure you're well aware, cooling system leaks influence operating temperature - and that operating temperature is reflected by the temperature gauge. Hence, a 15 PSI cap on a 200 Series Jinma can skew temp gauge readings. But I only asked the OP the cap question, as one step in the troubleshooting process. Since he's still using the OE cap, this doesn't apply.
SMALLJOBS - Having said all that, the OE cap springs aren't very robust. As part of your repair effort, I personally recommend a low pressure aftermarket cap. Don't hold me to this number - I don't have those Jinmas anymore. But I'm thinkin' I used a Stant 10282 on them. If you hunt long enough, you may eventually find an old 4 PSI cap to fit. Short of that I found the 7 PSI Stant to stop the weeping caused by it's stouter 15 PSI cousin.
//greg//
Today I turned on the key, had my wife watch the gage while I ran a jumper from the sensor to the block. It pegged the gage at the other end. Will replace sensor and report back.
/ Trouble Shooting "Low" Operating Temperature #11
[[[As I'm sure you're well aware, cooling system leaks influence operating temperature - and that operating temperature is reflected by the temperature gauge.]]] Hence, a 15 PSI cap on a 200 Series Jinma can skew temp gauge readings. But I only asked the OP the cap question, as one step in the troubleshooting process. Since he's still using the OE cap, this doesn't apply.
SMALLJOBS - Having said all that, the OE cap springs aren't very robust. As part of your repair effort, I personally recommend a low pressure aftermarket cap. Don't hold me to this number - I don't have those Jinmas anymore. But I'm thinkin' I used a Stant 10282 on them. If you hunt long enough, you may .eventually find an old 4 PSI cap to fit. Short of that I found the 7 PSI Stant to stop the weeping caused by it's stouter 15 PSI cousin.
//greg//
[[[Yes, now I see. If it leaks long enuf to lower the coolant level it makes it run hotter. To me this is causing the gauge to read differently, altho probably not skewing it. However, once enuf coolant is lost, causing many alarming indications, the gauge wont be immersed in coolant and may start to read low. That would be skew.]]]
The OPs tractor is full of coolant and is running cool. The pressure cap is not the issue even if it were a high one. Your point that he should not use a high pressure cap is distinct from this, and a valuable point of information.
Oh, and the reason for increasing coolant pressure is to allow the coolant to run hotter w/o boiling. [This is a particular problem in todays higher performance power systems where boiling can be a problem hidden in hot spots of the engine.] To a certain extent anti freeze elevates the boiling temp, but the heat exchange efficiency of the coolant decreases slightly as the water concentration goes down. Essentially you want enuf anti freeze for freeze prevention - and then take care of whatever extra boil resistance you need by increasing the pressure.
larry
/ Trouble Shooting "Low" Operating Temperature #12
Anti-freeze per se is falling by the wayside throughout the industry as coolants with SCA's are becoming more prevalent, convenient, and desirable, such as the Final Charge brand.
Engines must run warmer to meet emission standards, so thus have higher thermal effencies - the hotter, the better (to a point).
/ Trouble Shooting "Low" Operating Temperature #13
SCAs?.....
/ Trouble Shooting "Low" Operating Temperature #14
SCAs?.....
Supplemental Coolant Additive; a chemical package that is added to coolant either as a liquid, powder, or charge inside a filter. Most commonly formulated to combat cavitation and corrosion. You can buy it as a concentrated additive from auto parts stores, or in pre-mixed containers, most commonly gallons. Most anti-freeze companies make at least one; this Florida list alone ( http://www.doacs.state.fl.us/standard/petro/afbrands.html ) lists about a dozen and a half. The stuff's good for all liquid cooled engines, although it's most commonly sold to diesel operators - and is considered a must for wet-sleeved diesels. Owing primarily to availability, I use Peak Final Charge 50/50 premix - although I have also used the NAPA concentrate (NAPACool, I think).
//greg//
Replaced sensor, checked sensor case to ground OK, started up tractor, no improvement. I opened radiator cap and put cardboard in front of radiator until temp reached 80C as measured inside top of radiator. Gage still won't go much over 40C.
I give up and will add a regular mechanical temp gage. If the gage and wiring is too sensitive to resistance I don't want to spend any more time on it.
/ Trouble Shooting "Low" Operating Temperature #16
I sympathize. But it's not that the gauge and wiring are too sensitive, they're just cheap. That said, I've had no problems with temp indications on my 4 Chinese tractors. Luck of the draw maybe. But given the circumstances, you have the right idea going aftermarket.
//greg//
Does anyone know the thread spec on the male end of the sensor? I went to the autoparts store and found a mechanical gage including "metric" adapters. Even I bring the sensor along, it's a male thread so there is no way to really check the adapters that come with the gage.
/ Trouble Shooting "Low" Operating Temperature #18
Unless you are very cost concious, I recommend the Murphy Switchgageï®.
I have one for jacket water temp. and one for oil pressure. They have adjustable setpoints for alarms and indicators.
Verified thread in engine is 3/8 NPT and the Autozone gauge and threaded adapters will fit fine. Will install and close this out. Thanks for everybody's help.
Sweeper attachment (A61567)
Sweeper attachment...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
