Tripple selector valve
/ Tripple selector valve
I haven't got back to working on it yet. I have kind of been waiting to see if anyone else had the same problem or if it was just me. I think there is a flaw in the first spool valve. When I get a chance I am going to the Cat dealer and see if they stock the first spool valve and see if I can compare them.
Bill
/ Tripple selector valve #22
Yes, I believe I have the same issue. Let us know if you find a solution.
/ Tripple selector valve #23
I think I would plug ports C1A & C1B. I would use C2A & C2B for the loader bucket, and use C3A to close the grapple and C3B to open the grapple.
/ Tripple selector valve #24
The only problem I see with that is you will always have to have a solenoid energized to use the curl.
/ Tripple selector valve #25
Bill,
When you disassembled the valve, did you notice if the 3 selectors are the same? Interchangeable?
/ Tripple selector valve #26
Sound's to me like he wants to use one control valve for two functions. If you hook the grapple to C1A/C1B. When using the grapple, no solenoids need to be energized, When you want to use C2A/C2B or C3A/C3B you will need to have two solenoids energized. So, everytime you change functions, you have to change states of two solenoids. Whats the difference between switching two solenoids, or switching to the one solenoid that you need ?
/ Tripple selector valve #27
C1A and C1B are on a solenoid that is normally not energized and allows flow thru the valve ports. You only apply power when you want these ports closed.
/ Tripple selector valve #28
No matter which way you do it. You will be shifting solenoids every time you change functions. In truth table #1 you would be using C1A/C1B & C2A/C2B Not C3A/C3B. In truth table #2 you would be using C2A/C2B & C3A/C3B. Not C1A/C1B.
/ Tripple selector valve #29
George,
No one is arguing the need to activate 2 solenoids to change function. The problem is you only need the action of the grapple for a very short period, plus when the grapple is not attached and you are using the bucket you will never use that second function.
It is probably not a good idea to be sucking 12v power to keep the 2 solenoids actuated under the normal use situation. It may or may not shorten the life of the solenoid (after all it is just an electromagnet) but it is certainly using energy when it should not be needed.
/ Tripple selector valve #30
George,
Great discussion...I have been looking at a Land Pride RBT3584 rear blade and was wondering about powering the hydraulic functions. I had come across the SC triple valve but I am even more electrically challenged than hydraulically. What I was looking to do was have one circuit power three functions - 1) blade angle 2) blade offset and 3) blade tilt. If I read the description right, I could have angle in the unpowered state and then the various combinations to power the other two combinations. What sort of electrical selector switch have people used?
Does this seem workable? It would mean one electrical connection and one hydraulic connection to hook up the implement but seems doable.
thanks for the thoughts.
/ Tripple selector valve #31
Bill, How are you making out?
Oops ...looks like I should have read more search results first. Sounds as though you did exactly what I am thinking about. Thanks all for the info. I will read more and look at schematics.
Bill,
I was hoping they were but they are not. That would have been to easy.
George, the first circuit is prioritized so you dont have to have power to it to use that function.
I would like to find out who the manufacture is so I could contact them with questions. I think this valve is fine for single cyl. aplications but I dont think it will take the flow of two cyl. With work,racing and yard work my time has been limited.
Bill
I finaly gave up and replaced the tripple selector valve with this valve from Surplus center SAE 8 15 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-2. After installing the new valve every thing is back to operating as it should. Maby I will use the tripple selector for T&T or somthing.
Bill
2008 GMC C7500 WATER TRUCK (A67714)
2008 GMC C7500...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2006 FORD F-450 SUPER DUTY SERVICE BED (A67714)
2006 FORD F-450...
STORGE SPACE WITH MISC ITEMS (A68842)
STORGE SPACE WITH...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
