triple gear pump o rings
   / triple gear pump o rings #1
Luckydog018
pittsburgh pa
2000 bobcat mini excavator 325
ok So I have a 2000 Bobcat mini 325. And I have a leak on what bobcats parts website calls triple gear pump. So I took the tee fitting off and replaced the oring with a factory o ring. and still leaks. took it back apart cleaned it up and tried it again, still leaking. so one more time this time new o ring and some black sealant and still leaking. i feel NO burs or anything on the tee fitting or in the threads of the pump.
Has anyone else ran into to? how can i fix it? Thanks:cool:
   / triple gear pump o rings #2
Inspect the pump housing for very fine hair line crack at the threads.
I did not notice any blemish at all on the threads
the one thing that i did notice is the washer on the fitting is kind of beveled not sure if it should be flat or beveled??
So i took the pump to a shop and when they tried to mill it, it uncovered a crack in the housing down through the threads. so looks like im screwed and need to buy a pump. anyone have a good one out there? pump # 6674941
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
25077 (A51694)
25077 (A51694)
40' CONTAINER (A51248)
TROY-BILT TB4216 CHAIN SAW (A51248)
TROY-BILT TB4216...
