triple gear pump o rings
/ triple gear pump o rings #1
Luckydog018
pittsburgh pa
2000 bobcat mini excavator 325
ok So I have a 2000 Bobcat mini 325. And I have a leak on what bobcats parts website calls triple gear pump. So I took the tee fitting off and replaced the oring with a factory o ring. and still leaks. took it back apart cleaned it up and tried it again, still leaking. so one more time this time new o ring and some black sealant and still leaking. i feel NO burs or anything on the tee fitting or in the threads of the pump.
Has anyone else ran into to? how can i fix it? Thanks:cool:
Inspect the pump housing for very fine hair line crack at the threads.
I did not notice any blemish at all on the threads
the one thing that i did notice is the washer on the fitting is kind of beveled not sure if it should be flat or beveled??
So i took the pump to a shop and when they tried to mill it, it uncovered a crack in the housing down through the threads. so looks like im screwed and need to buy a pump. anyone have a good one out there? pump # 6674941
Thomasville,Georgia (A63116)
Thomasville,Georgia...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
UNUSED KUBOTA BRUSH GUARD PART (A62130)
UNUSED KUBOTA...
(1) UNUSED 16.9-30 TIRE W/RIM (NO CENTER) (A62130)
(1) UNUSED 16.9-30...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
