triple gear pump o rings
/ triple gear pump o rings #1
Luckydog018
pittsburgh pa
2000 bobcat mini excavator 325
ok So I have a 2000 Bobcat mini 325. And I have a leak on what bobcats parts website calls triple gear pump. So I took the tee fitting off and replaced the oring with a factory o ring. and still leaks. took it back apart cleaned it up and tried it again, still leaking. so one more time this time new o ring and some black sealant and still leaking. i feel NO burs or anything on the tee fitting or in the threads of the pump.
Has anyone else ran into to? how can i fix it? Thanks:cool:
Inspect the pump housing for very fine hair line crack at the threads.
I did not notice any blemish at all on the threads
the one thing that i did notice is the washer on the fitting is kind of beveled not sure if it should be flat or beveled??
So i took the pump to a shop and when they tried to mill it, it uncovered a crack in the housing down through the threads. so looks like im screwed and need to buy a pump. anyone have a good one out there? pump # 6674941
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
UNUSED CFG INDUSTRIAL MX15RX MINI SKID STEER (A62130)
UNUSED CFG...
100 GALLON METAL TANK (A62130)
100 GALLON METAL...
2007 Ford Focus Hatchback (A61569)
2007 Ford Focus...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
