triple gear pump o rings
   / triple gear pump o rings #1
Luckydog018
pittsburgh pa
2000 bobcat mini excavator 325
ok So I have a 2000 Bobcat mini 325. And I have a leak on what bobcats parts website calls triple gear pump. So I took the tee fitting off and replaced the oring with a factory o ring. and still leaks. took it back apart cleaned it up and tried it again, still leaking. so one more time this time new o ring and some black sealant and still leaking. i feel NO burs or anything on the tee fitting or in the threads of the pump.
Has anyone else ran into to? how can i fix it? Thanks:cool:
   / triple gear pump o rings #2
Inspect the pump housing for very fine hair line crack at the threads.
I did not notice any blemish at all on the threads
the one thing that i did notice is the washer on the fitting is kind of beveled not sure if it should be flat or beveled??
So i took the pump to a shop and when they tried to mill it, it uncovered a crack in the housing down through the threads. so looks like im screwed and need to buy a pump. anyone have a good one out there? pump # 6674941
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
UNUSED CFG INDUSTRIAL MX20R EXCAVATOR (A51247)
UNUSED CFG...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
