Trimmer line?
/ Trimmer line? #1
Kenneth in Texas
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
My cub cadet finally ran out of string today, instructions say to use .105 "SplitLine" trimmer string, which i assume is a dual string stuck together, where would I find such a creature? Ive googled it and no such luck. First time in 30 years ive ran into a trimmer that uses anything other than regular trimmer string. Can someone enlighten me on this?
/ Trimmer line? #2
105 is pretty heavy.
They push the Splitline because its their own brand (troy built is Cub is MTD)
Hers the -095 Shop Troy-Bilt 30-ft Spool 0.095-in Trimmer Line at Lowes.com
I use and like the Stihl Xline in -095. Its tough, but not so tough as to tear up siding if you slip. Object moved Green
For real gnarly stuff, the Oregon Gator line is super tough, just watch it around siding or you'll have a nice hole.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2008 Sterling L7500 Series T/A Vactor 2115-824 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
