SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,644
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
The walking beam effect of a wide front also smooths out the tractor front. Deere, however, did come out with a patented design call the Roll-o-matic which allowed the two wheels on a narrow front end to oscillate thus smoothing the ride somewhat.
My 2010 has that.
Well, In consideration of details.
The pivot on a pivoting solid axle is a line at the center of the tractor (the pivot pin.) While the pivot location for a "typical " tricycle is the out edge of the tire. so some what "further out" than the centerline axle pivot.
That was my "first pass assessment" and basis for the comment of preference.
There are a lot of variables in the mix, even ground conditions.. mighht take a fine pointed pencil to figure the difference ;-)
But I will conceed, The pivot point of a tricycle gear is at the ground!
cheers
Yes; the Roll o Matic "walking beam" simulation may have 2, but has both wheels supporting weight equally over uneven terrain. So pivot is centered and at ground level like a single wheel.Actually there are even some single front wheel tractors so the pivot would be centered.
I've spent a lot of time on both and IMO opinion it's not even close a wide front is more stable.
I have long experience on our 2010 tricycle on slopes, and a little less on our 4 wheel loader tractors. The 3 wheel is pretty stable, but driven with more care. Lack of a roll bar and no second chance if a rear lifts tends to make you that way. Iv lifted a rear many times with 4 wheel loader work.
larry
