countrybumpkin
Elite Member
- Joined
- Jun 14, 2005
- Messages
- 3,243
- Tractor
- Kioti, kubota
You could fab up a homebuilt Dragline, that you could pull under the overhang.
I like that answer because it'll be easier to do part of the job. The rest is complicated by a boulder that's as wide as the middle third of the cottage. It sticks up about 8" above the ground, and goes down farther than I've cared to dig. Any suggestions about how to handle that?
The reason I think he boulder doesn't go all the way to the foundation wall, so I can put a drain at the X, is that groundhogs dig burrows along there.
I have operated a dragline, and as Moss said, you need a way to control how deep the bucket goes.
A dragline has two cables, one that pulls the bucket toward the machine, and one from above that limits the depth it can reach. You need both. And, you can't do that in 18 inches of space.
Without the upper cable, the cutting edge of the bucket will turn down, and bury the bucket so deep, you won't be able to pull it through.
I am not a big fan of no dig, interior basement drainage systems. But this job may be the perfect candidate for it.
That or hire a company to horizontal bore that can pull in a perforated pipe. There are a lot more companies available to do this type work now than in the past so it is more competitively priced than years ago.
I would not be comfortable with that. Without a properly prepared bed of washed stone, you could still be in deep water.
I have seen the existing stone bed harden to the point that it had to be broken up with a pneumatic chipping hammer. The water was not getting through it. But, it sure found it's way into the basement.![]()
A percolation test of the OP's soil would show whether it is feasible or not. Not all sols are the same and I did recommend diverting the water above the house too. In these situations you do what is feasible If the OP installs a French drain that is slightly lower in the rear of the house than the downhill side of the foundation he will stop the large portion of the water infiltration. This drain should run around the perimeter of the house and make the foundation in a manner of speaking an island. If the water is coming straight up he will still have problems. But in my experience it is a good well founded 95% solution.
