Tree Wrap of Doom
   / Tree Wrap of Doom #11
I did something similar working some gravel on a slope right next to a tree. it slid sideways and trapped the tree between the right front tire and the right hand step. I thought I was going to have to get the saw, but I managed to use the turning brakes and after a lot of inching with the hydrostat and the turning brakes, I managed to get it loose. Moral of the story is not to work too close to trees on a slope if the tree is downhill. Sooner or later you will be up against the tree.
   / Tree Wrap of Doom #12
How to unwrap from a bad tree wrap:
1. Tie a rope to the tree so when it falls it won't fall on the tractor when you cut it.
2. Tie the other end to your tractor so you can apply tension away from your trapped... trac...wait...
New plan...
1. Buy another tractor....
   / Tree Wrap of Doom #13
I've run into that a couple times now. So far, been lucky enough to be able to crab sideways uphill, to be able to drive out. Last time was close cause the ground was so soft.
   / Tree Wrap of Doom
First, I had to drop the tree to get out. Yes, I probably could have used a come along / d8 to pull me out but that wasn't in my cards. Got plenty of trees and this is an area I am clearing. Just dropped it on the tractor... PT's are all steel so unless it is a monster (this was maybe a 10 or 12" trunk) the tractor is going to be unaffected. I have had a good 18" top of a dead tree hit the FOPS while moving around in the forest. I was one heck of a bang but no damage.
What got me was that I slid in such a way I could not move at all. Crab, spin, inch, nothing. I have been tree wrapped a bunch of times but this was the first where I was stopped dead with the tree between the engine compartment and the FOPS.
actually cutting the tree proved to be a big issue. Lots of tension on the FOPS and engine compartment so I ended up pinching the blade on the saw a few times.. Glad I was deep down in a ravine because the air was thick with blue words.
Tmarks. Suggested you idea to the wife. Been sleeping in the truck since then thank you very much
   / Tree Wrap of Doom #16
I have had to cut the tree out once. Way down in the woods and the PT slid sideways on the icy slope while duals were on and I was real close to the tree. I could have taken the duals off or gotten a winch but it was a pretty long hike out, I had a chainsaw with me, and I have been squeaking by this tree with my fingers crossed for years. It was not one of the trees I had planned on yanking out that day but it heats the house just as well as one that was planned for removal.
The "blue words" - I will have to let my neighbors know that was you and not from me while working with the painter's tape from ****. Bought the good stuff and even though it was on for only a few minutes, it not only ripped off the paint on the wall but the drywall paper that the paint was attached to. Red Green could get rid of the duct tape and use this easy release tape instead.
Ken
   / Tree Wrap of Doom #17
Few months back I posted about a similar screw-up on Ventrac forum. Figured the guys would have a good laugh at the newbee. Turns out, several confessed to same experience. It was suggested to use the front implement and hydraulics to lift the tractor and articulated steering to scoot the front end away from the trap. But, on a decent slope and soft ground there is not enough purchase to do so. First time, I managed to get untangled. Second time, I had to use my other tractor and chain to skid the dual wheeled crab up and away from its snare.
prs
   / Tree Wrap of Doom #18
Did that once with my Dad's tractor when I was 13, only it was against a telephone pole and not a useless tree. Boy was he pissed off. Had to dig a sliding trench for the tires, and then take the truck to yank it sideways out of there.
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
10222 (A56858)
10222 (A56858)
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
