Tree Shear???
/ Tree Shear??? #21
Came across a skid steer shears from Lackender Fabrications which they are advertising for $2500 to start. No specs were given, so if you are interested, you'll need to call. Their website is:
Lackender Hi-Reach
I would expect they could build one around the PT quick attach.
/ Tree Shear???
Buck14,
Thanks for the post and info. I spoke with mike and greg at gregorygrappler. Their unit sounds like it is probably the best on the market for what I am looking to do. only drawback is it will cost about $5-6K /forums/images/graemlins/shocked.gif. It sounds like the PT 1445 will handle it as far a weight and flow are concerned. However, this skid-steer like attatchment requires bi-directional flow not unidirectional flow like PT has /forums/images/graemlins/confused.gif
PT said they can add a solenoid that will provide bi-directional flow like a skid steer.
Questions - Has anyone added an aftermartket solenoid to switch the PT from uni-directional to multi-direction flow?
How complicated is this set-up? How elegant is this set-up?
Is there a reason why bi-directional flow should NOT be used on a PT???
Tracdoc, still waiting for lackender to call me back
Everyone, thanks for the input
/ Tree Shear??? #24
Changing the direction of flow isn't complicated. As PT mentioned it's only a selenoid or switching valve, which is the same thing the skid steers will use to change direction.
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61307)
Bulk Lot of NEW...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2014 Ford Taurus Sedan (A59231)
2014 Ford Taurus...
DEUTZ MARATHON...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
2006 Nissan Murano AWD SUV (A59231)
2006 Nissan Murano...
