Tree Removal with a Backhoe
   / Tree Removal with a Backhoe #41
My land has a lot of what I call 40ft stumps. Trees that died from being shaded out by faster growing trees. I don't see any safe way to deal with them. Some are so rotted the top can fall off from a small bump. I tried ONE time to push one over with my tractor. The top 5-6 feet fell back toward me. No harm to me or the tractor. Now I am careful to look up a lot when going in the woods. Large branches fall from the newer dead ones from time to time. I had one drop some 30 feet behind where I had just walked. It shattered when it hit the ground.
I have many of these as well. I have a 30' aluminum window washer pole. Put a slip knot on the rope - push it as high up as I can with the pole, cinch and then pull over with the truck. Most rotten ones will snap about an inch below the ground. If it snaps higher up, I just repeat the process on the remaining "stump". I only use 3/8 or 1/2 inch nylon rope. If it is too stubborn to pull down, usually the small rope will snap. At that point I figure it is solid enough to use the saw. With the lightweight rope, the tension causing it to break is not enough to do any damage to the truck
BUYERS PREMIUM & PAYMENT TERMS (A58018)
BUYERS PREMIUM &...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A58018)
2017 VOLVO VNL64T...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
1295 (A58374)
1295 (A58374)
