Tree problem
/ Tree problem #21
turnkey4099 said:
A-frame of heavy poles leaning over fence from neighbor side and well braced to keep the bottom from skidding. Legs placed a even with or even a foot or so back from the tree (pasture side of the tree). Then cut from the top back toward the A frame contact point. Once there, over into the pasture: cable to the snag portion up near the break to tractor, undercut, backcut, pull and the overhanging potion will swing right over the fence - no damage there.
Yep, lots of rigging and the a-frame will need to be (6x6 at a guess) fairly substantantial. Were I doing ti, I would have the cable/tractor all hooked up before doing much cutting on the top. Dunno what size your tractor is but I would want a fairly good sized one. With the set-up as described, the force on the tractor will not be overly great. I'd do it on my own place but for someone else, I would do the 'cut fence' way.
Harry K
<CORRECTION>
The A frame legs need to be set at least a bit away from the butt of the tree _toward the fence_.
Harry K
/ Tree problem #22
Tie the bull to the end of the tree that is in the pasture. Get in there with him and piss him off really good (a smack in the nuts works quite well). Make sure you are running away from the fence when he comes after you. If you make it out of the pasture alive, return later when he is tired from dragging the hickory trunk around and you should be able to cut it up and get it out of there.
Oh yeah, video tape the whole thing and you will be very likely to win $10,000 on America's Funniest Home Videos!
/ Tree problem #23
I may have missed something in the comments above but from looking at the photo it looks like the problem is the responsibility of the neighbour as the tree fell from his side. That's the way the law works in my area. Of course it is neighbourly to offer to help but not do the whole job of fixing the problem.
/ Tree problem
There's no issue about whose problem it is. I just was looking for ideas to get the thing down without damaging the fence. I even get all that nice hickory firewood to heat my house next year! :) I don't mind cutting up the tree at all, and the neighbor's hired hand doesn't mind the work of getting it down. We just don't want to cut or smash the fence.
/ Tree problem #25
I would put the top in the bucket and drop it back over the fence. Once on the otherside you can pull it 180 degrees from where you found it, and then just cut down the tree.
jmf
/ Tree problem #26
For those of you interested I've attached page 49 from the Sherril Arborist catalog showing the weight of a 1 ft length of tree for a variety of species by diameter.
This might help you figure how much weight you're really dealing with.
  • Weight of wood.pdf
/ Tree problem
Great information! Thanks!
Based on that chart, averaging the diameter of what's hanging there, I have a section about 30 feet long weighing in at somewhere around 900 lb. with one end still attached 14 feet or so above the ground and 5 or 6 feet on the other side of the fence we don't want to harm.
My 54 inch wide tractor will lift about 1200 at most, and to get hold of this thing at the balance point I would need to raise my bucket to nearly the full height. Factor in the uneven ground and I think trying to pick it up with my tractor and set it back over the fence is a recipe for a rollover, even if there was room to swing it, which nearby trees prevent.
I think I'll just wait for the big front loader to get it cut from the other side.
/ Tree problem #28
DT - you're welcome for the chart. Of course we all know trees are heavy but the chart brings some real numbers to the table. I'm glad the data helped you decide to wait for a bigger/safer machine.
/ Tree problem #29
You're going to have a deep freeze this weekend that will last several days. The mud will be gone and you should be able to get it done then.
/ Tree problem
That's my hope.
The chart is interesting. I printed it and it came out small. I went looking for a bigger version and it seems there is not much information that people are willing to put into tables like that. Too many variables from tree to tree, I guess. There is a site where you put in the species and mid-log diameter and it will spit back the approximate weight.
It seems people in some areas market or estimate the board footage of their timber by weight so no one is quite willing to put numbers out there. I never thought logging was so complex.
/ Tree problem #31
Good reasoning, that's why your Da Teacha.:)
/ Tree problem #32
To Weight and not to wait. It doesn't appear to be going any where fast, so time is on your side. If you needed to do it with what you have I would tie it off to another tree on your side of the fence and just start cutting off logs as high as you can safely reach. This will shorten the top half putting it above the fence. You then could cut down the tree and drop it on the other side.
jmf
/ Tree problem #33
After thinking about this, the only thing I would do is suggest to my neighbor that he get a fairly heavy piece of chain (5/16" or 3/8"), climb up a ladder to the break and chain the top of the tree to the stump in such a way that if the "hinge" were to break, the top of the tree would be supported by the stump and not fall on the fence.
Wait until the land dries out and then let him deal with it with his larger machine.
If you absolutely have to do something about it, keep the safety chain in place and using another chain at least several feet longer than the remaining tree top, attach the chain near the upper end of top of the tree, close to the ground, and drag the top parallel to the fence to a point where it is making about a 30 degree angle with the fence when viewed from overhead. (See attached diagram)
Now, drive a tee post or something similar next to the end of the top top of the tree, and chain the top to the post, so you know it will stay in place when the tree comes down.
If you neighbor can support the weight of the trunk with a big enough loader or tractor, remove the safety chain, cut the hinge, and lower the tree on your side of the fence.
If he can't get there with a big enough machine, you are faced with the issue of how badly you want to save your tree.
In any event you need to attach a guide, maybe a 2x8 or so to the stump high enough up to guide the tree over the fence when it comes down. It is hard to tell, but if you trim the tree carefully near the hinge you may be able to prevent it from hitting your tree when it comes down. If not, I would sacrifice your tree, so that the larger tree doesn't hit it and cause it to fall back over the fence, negating all the work you have done so far...
Anyway, attach the guide, remove the safety chain and cut the hinge, preferably with a pole saw.
/ Tree problem #34
IMO this thing is being grossly over engineered. The problem is how to remove the broken top without hitting the fence.
That will require propping it up so it can be 'chunked' back as far as possible without the chunks hitting the fence.
Simplest way is a set of shear legs, an A-frame of 2x or 4x stock crossed at the to form a 'V' notcth for under the top. Bottom best on the tree side of the fence leaning over it. Per the chart it only weighs 900 lbs which is partly supported by the tree.
Now cut back the top as far as possible without the chunks hititng the fence.
You now have the tree standing solid, the 'stub' solidly propped. Neither can go any place assuming of course that the broken hinge doesn't completely let go and per the picture that is extremely unlikely as long is it isn't allowed to move.
Just a matter of falling the tree away from the fence, as it falls the stub will follow clearing the fence. You can be assured the tree will fall away from the fence by either pulling on it from the pasture side or pushing from the fence side with bucket (use a 'push pole' if needed, if so another A frame will do). Probably could just push on the stub to start the tree in the right direction.
Harry K
/ Tree problem
Okay, the tree is down, all on my side of the fence, no damage to the fence.
With the hard freeze this weekend, the neighbor brought his big Cat payloader in to where the tree is. He set the bucket (about 10 feet wide, at least!) where he could chain the tree to it, then set about cutting the hanging part free from the stump. It was still hung up in my small tree, so we cut about 6 feet off the top (ground contact end) and then he managed to move the thick end over on his bucket. After cutting off about 3 feet of split section, he dropped the rest down on my side of the fence.
I had underestimated the size of the thing. My 16" chainsaw bar was too small to cut completely through the log at a point that would have been about 15 or 16 feet off the ground on the standing tree. That, in conjunction with the handy chart provided a few posts up, plus the fact that my DX29 was not able to lift the shortened section laying on the ground leads me to figure the whole part that was over the fence was pretty close to 2100 lb. maybe more. It would definitely have been a not fun situation if I had managed to dislodge the thing with my tractor.
The butt of the tree, cut off and set over the fence, is around 14 feet long, probably 18" diameter at the top, and somewhat bigger at the base. Using the chart again, this shorter section of hickory comes close to 1950 lb. Again, not something the DX and the LX114 loader is going to move.
Later in the afternoon, I moved some cut up Cherry. It seemed to almost weightless in comparison.
Thanks for all the advice guys! It's been an educational thread
Rich.
/ Tree problem #39
I think he was talking about photos of the take down... and the Cat payloader :)
/ Tree problem
Oh. I didn't get any of those. I was headed out on another mission when the guy showed up on his side of the fence. The payloader had tires that are over 6 feet high and probably weigh more than my entire tractor. It literally used to be used in a open pit sandstone quarry/mine not too far from here.
BTW, those tires are also about 30 inches wide or more, mostly R4 design, but worn to the point of being almost slicks. He didn't bring the thing out until the ground was frozen because it was sliding around in the mud too much, damaging the pasture. I think he also figured it would slide down the slope and squash the fence worse than the tree. :)
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
Landhonor 2-Ton Hand Chain Lever Hoist (A66408)
Landhonor 2-Ton...
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
