Tree Felling danger
/ Tree Felling danger #1
retiredmgn
Platinum Member
DSCN0403.jpgDSCN0404.jpgDSCN0406.jpgSo I was going about my usual logging. I was cutting an ash bout 18" at the butt. The tree was leaner so I was confident of direction of fall. Before I finished the cut the tree "BLEW UP". Never seen anything like it. Once my razor sharp reflexes kicked in I fell backwards and planted my face in the ground. :rolleyes:
There are several scenarios for 'widow makers'. Add one to the list.
/ Tree Felling danger #2
That's something. It doesn't look like it was rotten in the middle or anything. Looks like it just split down the middle. Not sure how you could possibly have seen that coming. Yet another reason why leaners are dangerous. I wonder what a professional arborist or logger would/could have done differently.
Glad you didn't get hurt.
PS: I'm assuming you're not a pro, but if I'm wrong, I apologize, and I'd love to hear more from you on the topic. I drop a tree or two every now and then, but only the "easy" ones and I'm always interested in learning more about safety.
/ Tree Felling danger #4
Always remember on leaners ( widow makers ) there is abundant stored energy in the leaning tree and the ones it is leaning against....hard to know what the reaction to making the cut will be....very scary situations...Think of huge rubber bands pulled tight and then you cut into the main one....Yikes ! Glad you are OK...
/ Tree Felling danger #5
That's what is called a 'barber-chair'. Certain species of tree with specific grain structures are especially prone to this, ash being one of them. Leaners are even more prone to this, because of the extra stress on the holding wood during the backcut.
See this thread for a good explanation and some tips: http://www.arboristsite.com/tree-care-videos/177328.htm
/ Tree Felling danger #6
With a lean you need to make your face cut then plunge through to make your hinge (being careful of kickback and not leaving your hinge too thin) then cut from hinge to the back instead of from the back in.
You can also chain the tree above your cut to help prevent it from splitting out.
/ Tree Felling danger #7
+1 on chaining or strapping above the cut. Look closely at the trunk for any sign of cracks or rot when working on something with a lean in it. Thank God you didn't catch that in the face. We would be reading your obituary instead.
No rot. Sound wood. Will burn well.
No, I'm not a pro. I put up 6 cords a year for the following year.
A pro would probably have seen such a thing before and put on his spikes and started from the top down. Or find someone else to do it. ;)
Bob, the tree was a 'natural' leaner. It wasn't hung up on any thing. This was the initial cut. I've been known to leave cut leaners alone and let the next big wind bring them down for me. If it falls in the night I really don't care if anyone heard it. Sucker is down and I'm safe.
/ Tree Felling danger #10
Not a lot of climbers will opt to go up a leaner if he has the option to cut it from the ground. At least I don't if there is a safe place to land it.
Good vid. Exactly what happened. And I did hesitate on the back cut. It's a habit of mine. I pay alot of attention to the hinge to angle the fall to where I want it. It was when I took a moment to double check my final situation before sawing through. The decision was made for me.
/ Tree Felling danger #12
OK ..Nelson if it was a natural leaner I am surprised it reacted that way to your cut....sure am glad you came out OK...I am starting to slow down a little on my reflexes so I am super careful on the ones I choose to tackle...I wear a Tshirt that says...inside this old guy is a young guy saying what the heck happened....LOL
Yeah I was stretching it a bit with my comment of, "razor quick reflexes". It twernt pretty. It was elbows and a$$holes crawling away from that thing.
My usual rule is nothing more than 10" diameter but I really need some straight grain ash for fire starting. And it was there.
/ Tree Felling danger #14
^^^ This man knows what he is talking about.
Wrooster
/ Tree Felling danger #15
Wrooster
Very good illustration....everyone should watch the video...I want to add this...I learned it the hard way years ago...When you go up to a tree to cut it down...look for your runway....that is the path you will take if things go wrong...really wrong and fast...be sure there are no obstacles ...no vines ( that is what tripped me up one time ) no holes or fallen limbs...be sure you have a clear escape path before cutting....
/ Tree Felling danger #17
It also looked like the guy in the vid had his backcut at the same level as his undercut.
/ Tree Felling danger #19
Timely thread. Plan on felling a few leaning poplar later this year as they are looking like they are starting to die.
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2022 Bobcat T770 (A64126)
2022 Bobcat T770...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2020 Bobcat MT100 (A64126)
2020 Bobcat MT100...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
