Tree Doctors
/ Tree Doctors #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Just wondering if anyone has hired an arborist before? If so, did it help save your tree?
Thanks
Dave
/ Tree Doctors #2
Not me. My only trees are Ponderosa pines. I get Pine Bark beetle. The solution for the "beetle" - fell and burn the infected trees. I will loose three or four trees every year to the beetles. I have 80 acres of pine trees.
Good luck......
/ Tree Doctors #3
Thanks
Dave
Unfortunately, the only time we've used them was to cut down the tree from storm damage or disease.
/ Tree Doctors #5
Yes, we have had hired arborists over the years. Usually helpful, but the details of your issue(s) would help. Like many patients, not every tree is salvageable.
All the best,
Peter
/ Tree Doctors
Could you provide a brief description of what you have going on?
I have a large white pine that has thinning needles and some dead branches.
/ Tree Doctors #7
I have a 20 year old Norway Spruce doing the same thing.
Hope someone has an easy fix.
/ Tree Doctors #8
Contacting an arborist sounds like a good idea. Regardless of whether your tree is diseased or not, or whether it can be saved or not, a qualified arborist will be able to determine what is going on with it, and provide you an explanation.
From there, you may have a choice to make as to whether to pursue treatment. There are some tree ailments that aren't curable. Others are. And still others aren't really ailments at all, but just a life cycle of a tree.
/ Tree Doctors #9
A licensed arborist can make a world of difference to a tree that is starting to have problems.
Just make sure the person is a true arborist and not just a "tree trimmer".
I have seen many trees destroyed when someone has a landscaper or tree trimmer come in and take care of them.
/ Tree Doctors #10
We have lost a few to (what I GUESS is) white pine needle disease (WPND). It took a couple of years for the trees to die - I did not try to save them... not sure they could have been saved.
Lower branches dies off and work the way up the tree over the years...
/ Tree Doctors #11
Sounds like spider mites to me but only a certified arborist can make that decision and it takes a visual inspection. It can be sprayed but it takes a commercial spray rig to get to the top.
You wont find any cures on here, just postulation.
2009 TRAIL KING PNEUMATIC TRAILER (A67714)
2009 TRAIL KING...
2019 Ford F-450 Knapheide Crew Cab Service Truck (A66736)
2019 Ford F-450...
3 ROLL TOOL CARTS (A67714)
3 ROLL TOOL CARTS...
2022 John Deere 450K LGP Crawler Tractor Dozer (A66734)
2022 John Deere...
2000 FREIGHTLINER CENTURY CLASS DUMP TRUCK (INOPERABLE) (A67714)
2000 FREIGHTLINER...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
