treadle pedal
/ treadle pedal
KRUG, appreciate the info... What do you look for when inspecting the valve? Dirt trapped perhaps?, and should I expect much if any fluid loss?
/ treadle pedal #12
In a few cases, the stem of the neutral valve needs to be cleaned up with emery cloth. The plunger sticks on the stem causing the transmission to stick.
Pull the valves and lightly emery cloth the stem until the plunger moves freely.
A Way to check the valves before you do anything to them is to swap the forward and reverse neutral valves and see if it makes a difference in the performance of the pedal. If it does, clean up the valve stems as described above.
/ treadle pedal #13
Mine had a defective damper assembly. Seems better now, but cold weather will tell if it is cured, thats when mine acted up the most.
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
FORD F-250 (INOPERABLE) (A60736)
FORD F-250...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2022 John Deere R4023 (A60462)
2022 John Deere...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
