traveling washing machine
   / traveling washing machine #1
K_Daulby
Simcoe Ontario
BX 23s ,,BX 2200
anyone out there have any good sugestion for stoping my washing machine from traveling all over my basement
it is on concrete and is level. however when the load gets out of banlance it starts to travel. I put it back in position at least once a week if not twice. any sugestions will be appreaciated
thanx in advance
Kevin
   / traveling washing machine #2
Other than tethering it, the only thing I can think of is making sure all 4 feet are adjusted so ther're tight to the floor...............chim
   / traveling washing machine #3
I used rubber mounted bottom adustable legs..works fine.
Pick them up at Sears store.
   / traveling washing machine #4
Make sure the suspension springs are still all in position "under the hood". I had one break and we couldn't keep the washer in place.
   / traveling washing machine #5
is it a GE washer ??? if so...they have rubber straps that act as torsion stops on the bucket. they break....often.... and allow the bucket to slop around eventually messing everything up. pop the hood and see if you have them. this may be causing the strolling.
   / traveling washing machine #6
I echo the above posts. Something must be broken to cause it to move so much. Mine
is in the basement & I don't ever remember having it move around. Been there for 13 yrs.
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
AUGER SKID STEER ATTACHMENT WITH 3 AUGERS (A53843)
AUGER SKID STEER...
10ft Inclosed trailer (A53424)
10ft Inclosed...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
