Transporting Mini
/ Transporting Mini #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
The mini's are so slow to move 1/4-1/2 mile. What have you fabricated to facilitate moving them? I was thinking a stone boat (sled) or maybe the FEL on my 70 hp tractor. Or maybe a simple trailer. What are the fertile minds using?
/ Transporting Mini #2
Back when I had my two Toselli crawler tractors, I built a "low bed" trailer to pull with the tractor. It wasn't really about moving long distances but I have a asphalt paved area that I often had to cross with the crawlers with steel tracks between two orchards, so I didn't really wanted to damaged that asphalt.
I used some solid rubber tires with homemade rims and a lot of 90 mm pipe I had. I do regret getting rid of that trailer though. It was really nicely built.
I pulled it with the little Kubota B7000 I had.
/ Transporting Mini #3
I had seen on Gold Rush where Tony had put just an axle with a couple of duallies on each side on one end of the excavator . The bucket was put into the back of a haul truck and lifted the other end off the ground and was then pulled along to wherever he wanted to go. In his case it was a huge machine and it was a set of dualies on each side, you could probably do the same with a single on each side especially if you're off road.
/ Transporting Mini #4
Put it on a pallet?
/ Transporting Mini #5
small axle with a frame and hitch works. Dont take much to hold them up since the are so light.
I haul mine in the dump trailer to where I need to dig at the farm. Here at home I just drive it! Way faster than loading/unloading it.
/ Transporting Mini #6
One of the accessories you can buy with the 1-ton-ish mini from China is a very simple 1-axle trailer. Only a few hundred dollars and no suspension.
But any decent CUT or utility tractor should have forks. Even my Kioti can just
barely lift it. A bigger tractor, no problem.
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Ford Metal Tailgate Sign (A64557)
Ford Metal...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
2014 Jeep Patriot SUV (A64557)
2014 Jeep Patriot...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
