Transportation Chain and Binders
   / Transportation Chain and Binders
I had no issue with what you said, think your comments were right on the money. I was responding to another poster's opinions.
Don't quite agree with your calculations above, tho'.
In what way exactly? I'm new to this, but the numbers are from the DOT. Which calcs am I doing wrong. Open to critique.
§ 393.106 What are the general requirements for securing articles of cargo?
(a) Applicability.
The rules in this section are applicable to the transportation of all types of articles of cargo, except commodities in bulk that lack structure or fixed shape (e.g., liquids, gases, grain, liquid concrete, sand, gravel, aggregates) and are transported in a tank, hopper, box, or similar device that forms part of the structure of a commercial motor vehicle. The rules in this section apply to the cargo types covered by the commodity-specific rules of §393.116 through §393.136. The commodity-specific rules take precedence over the general requirements of this section when additional requirements are given for a commodity listed in those sections.
(b) General. Cargo must be firmly immobilized or secured on or within a vehicle by structures of adequate strength, dunnage or dunnage bags, shoring bars, tiedowns or a combination of these.
(c) Cargo placement and restraint.
(1)
Articles of cargo that are likely to roll must be restrained by chocks, wedges, a cradle or other equivalent means to prevent rolling. The means of preventing rolling must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit.
(2) Articles or cargo placed beside each other and secured by transverse tiedowns must either:
(i) Be placed in direct contact with each other, or
(ii) Be prevented from shifting towards each other while in transit.
(d) Aggregate working load limit for tiedowns. The aggregate working load limit of tiedowns used to secure an article or group of articles against movement must be at least one-half times the weight of the article or group of articles. The aggregate working load limit is the sum of:
(1) One-half the working load limit of each tiedown that goes from an anchor point on the vehicle to an anchor point on an article of cargo;
(2) One-half the working load limit of each tiedown that is attached to an anchor point on the vehicle, passes through, over, or around the article of cargo, and is then attached to an anchor point on the same side of the vehicle.
(3) The working load limit for each tiedown that goes from an anchor point on the vehicle, through, over, or around the article of cargo, and then attaches to another anchor point on the other side of the vehicle.
[67 FR 61225, Sept. 27, 2002, as amended at 68 FR 56208, Sept. 30, 2003; 71 FR 35833, June 22,
https://www.govinfo.gov/content/pkg/CFR-2010-title49-vol5/pdf/CFR-2010-title49-vol5-sec393-108.pdf
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
CAT 336E (A58214)
CAT 336E (A58214)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
