AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,420
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
After a bit of thought... pressure test the system. Check the radiator cap and the thermostat. You might have a worn out cap and/or a sticking thermostat. Also look for any signs of coolant in the engine oil or vice versa - oil in the radiator/antifreeze mixture.
You see anything like those conditions - you've got more serious issues like cylinder pitting, head gasket leaking or a cracked cylinder head.
You might also consider draining the system and using a radiator cleaner to flush the radiator and refill with new coolant. Especially if this hasn't been done in a number of year's.
Along this same line of action - you could also remove the radiator's and have a local shop (dealer might be able to do it) boil the radiator's in a cleaning tank. Not as routine a procedure as was the case a number of year's ago - but when radiator cores are damaged or begin to seperate from the housing - they are typically "boiled" before re-soldering.
IMO - if you take things all the way to this last level - replace the water pump and thermostat, too.
Beginning with blowing the radiator's out with compressed air and running in a lower gear, etc. the previous steps are what I would do if I were trying to resolve a "hot tractor" problem.
Good luck.
AKfish
Good luck.
AKfish
