Transmission noise.
   / Transmission noise. #1
CelticKubota
When I engage either forward or reverse I get a loud, creaky, dry, grunt off the Kubota . Once the I move 6" the sound is gone - it's only on takeoff. Its a B1750 HST.
What's causing it and how can it be solved.
   / Transmission noise. #3
I agree with Ron, your either your rim to spider bolts are loose or your lug nuts are loose. Check the torque spec in the manual and tighten them up. When you re-torque them, break them loose and then raise the wheel off the ground. Remove the nuts and coat the threads with never sieze and then torque them to the specs listed in your manual. Tighten them in a progressive manner using an X pattern. The dry "grunt" tells me that there is probably corrosion on the nut faces. The never sieze will eliminate that.
   / Transmission noise. #4
Check out my post..
Wheel noise..errrnt, errrnt....
It may help.
-Terry
Kennco 3pt Single Row Bed Shaper (A50120)
Kennco 3pt Single...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
2023 Power Compact Equipment PX320-L Mini Wheel Loader Skid Steer (A50322)
2023 Power Compact...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2011 Kubota KX080-3 Midi Excavator (A50322)
2011 Kubota...
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
