Transmission Fluid not there
/ Transmission Fluid not there #1
weedsportpete
Weedsport, NY
BX2200
Got my first tractor, a BX2200, on Saturday. Had already read the manuals, but asked a lot of questions. Had to wait a couple hours before I could get on, but I finally did and brush hogged for 3 hours. Yesterday I checked the transmission fluid and nothing showed on the dipstick. Checked three times; same. Ran engine for three minutes, then shut off and checked again. I thought I saw a sheen of oil on the stick, but not as easy to see as the engine oil on its dipstick. So I ran it three more hours and checked it again. It was dry. Tried again; still dry. While brush hogging I smelled something like burnt brown sugar.. was that just the weeds burning in the bush hog? Or was it the transmission? Have I damaged the transmission? I parked it on dirt; today I'll park it on concrete to look for leaks. The manual says use Kubota Super UDT oil.. is that required? I'm thinking about calling the dealer and asking them to come out.
Pete
/ Transmission Fluid not there #2
When in doubt on something this important, get that dealer on the phone!!!
Pete
/ Transmission Fluid not there #3
It does not take very much to be off the dip stick. Get some Super UDT and add enough to bring it up to the full line. I would NOT run it with the fluid low.
OK.. I'm not going to run it. The salesman is coming out tomorrow anyway to attach the MMM (good thing they couldn't find the part last week..) so he'll take a look at it then. I hope it is just a little low, just enough to be below the dipstick level. I'll have to get some super UDT though, for cases like this.
Thanks!
Pete
/ Transmission Fluid not there #5
I am not sure I follow, were you expecting spontaneous generation of fluid? If you checked it and it was in fact low--why did you continue to run it and check it over and over--you should have stopped then? The burn't smell could have been the transmission, it is possible.
On the bright side, it takes very little fluid missing to drop off the stick and it is very diffucult to see so maybe it was actually not so bad afterall.
When in doubt, stop and regroup, charging blindly ahead only works in the movies. Goodluck, hope it is not expensive. J
/ Transmission Fluid not there #6
Get in the habit of checking all your fluids regularly; I check the oil daily and the hydro fluid (sightglass) every couple of hours. Ditto with your fasteners, but not so often. Figure out a method that works for you and memorize the checklist. Low cost insurance to prevent catastrophic failure.
I'm a little puzzled. This is a brand new tractor, right? It had all the fluids checked before delivery? Just goes to show you that when it comes to caring for your tractor, never assume the other guy got it right!
Pete
/ Transmission Fluid not there #7
Can there be too much fluid. My level is above the mark, and I asked the dealer. (bought BX2200 2 weeks ago) The dealer said it was because of the FEL and this was normal. What would happen if there is too much?
/ Transmission Fluid not there #8
UDT is very hard to see on the dipstick. I find that laying the end of the dipstick on a small piece of cardboard or paper (I always have some paper towel when I'm checking over and/or greasing) quickly shows where the fluid is on the stick.
Good idea.. I'll do that. That should make the difference between 'I think I see it' and 'I just can't see it'..
/ Transmission Fluid not there #10
My understanding is that in general, you do not want to overfill. I've read it in manuals, but can not find one at the moment.
Generally, the fluid has to go somewhere; if the "container" only has room for a quart, then the rest will have to go someplace it wasn't meant to. Figure too, the hotter the liquid, you will have some expansiion, which will cause the level to be high until it cools.
Having the loader should not cause the fluid to be high; the fluid will stay in the loader. Yes, you will have a larger overall capacity when you figure in the volume that is in the hoses and cylinders, but the fluid should stay there.
/ Transmission Fluid not there #11
Dabota, That's the same method I use for checking the hydro fluid ... I use those blue Scott towels and just lay the yellow stick on the towel and you'll know immediately where the level is.
<font color=blue>So I ran it three more hours and checked it again. It was dry. </font color=blue>
I'm with you on this one, Tres ... this is the silliest thing I've ever heard.
Jeff
/ Transmission Fluid not there #12
How about - I cut it twice and it's STILL too short ....
Brad in NH
/ Transmission Fluid not there #13
Not making fun of Pete, we all do dumb things and I continue to do dumb things--it is true, it is my specialty and I am good at it. Nonetheless, this is how the "my Kubota quit running with only 34 hours and it is a Lemon" legends get going. Usually, and the same for JD, it is a owner induced malfunction, I do not believe in lemons unless they are hanging from a tree and yellow, not orange. J
The MMM was delivered and attached yesterday and the serviceman checked the transmission fluid. It was just a little short of the dipstick. He added more and left an extra container of UDT. I'll try it tonight. Hopefully my panic attack will be over then.
/ Transmission Fluid not there #15
Glad to hear everything is cool, Pete. /w3tcompact/icons/cool.gif
Jeff
/ Transmission Fluid not there #16
I always keep extra fluid for every sump on the tractor on hand; 15W-40 engine, NH hydraulic oil, and antifreeze. If your tractor uses gear lube in the front axle get some of that too. If it looks low add some. Ditto on putting the dipstick on paper or a rag to check the fluid level. I usually check it cold before I ever start the engine.
JT
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
