Transmission Drain Plug Size?
/ Transmission Drain Plug Size? #1
Ichabod
Would anyone happen to know the size and pitch of the transmission drain plug on a JD 2305 tractor? I can't seem to find this information on the JD website ... I have looked and looked. Thanks for any and ALL help ....
Ichabod
/ Transmission Drain Plug Size? #2
I take it you can't find yours?
I think the cat ate it; or, the dog took it and buried it!!
Ichabod :eek:
/ Transmission Drain Plug Size? #4
My 2320 (which i am pretty sure is the same engine) is a 16mm x 1.5. I recently installed a Femco drain valve on it and verified it with the dealer before I ordered the plug
good luck
Brian
thatguy,
are you referring to the "engine" or the "transmission" drain plug size? i read it as you're speaking of the "engine" drain plug size as 16mmx1.5 ... i need the "transmission" drain plug size ... unless they are both the same? some clarification please?
tx
(confused :confused:) Ichabod
/ Transmission Drain Plug Size? #6
thatguy,
tx
DISREGARD - I misread your original post - what i posted was the engine oil drain plug size.. sorry for that..
Brian
/ Transmission Drain Plug Size? #7
The best I can figure from parts diagram is 12mmX30mm long. It is part number
LVU800462. It does not give specs on thread pitch. The gasket part number is M808459. I hope those are correct numbers. The diagram is not too clear. Item numbers 39 and 40.
