translate please!!!
/ translate please!!! #1
Steve C
Platinum Member
North Central Michigan
Farm Pro 2425
I have a Farm Pro 2425. I bought it used and don't know if the cylinder head has ever been re-torqued. It has about 83 hours on it now and I want to get it done. Can someone tell me what the torque for the head bolts is in american terms? I am not much into metrics. I want to torque the head and set the valves lash.
/ translate please!!! #2
It may depend upon which engine is in the tractor. Consult the engine manual for the metric specs, they're likely in Newton-meters. Divide Nm by 1.3558 to get ft-lbs
//greg//
//greg//
thanks,I have all the manuals and the tool box and gaskets
/ translate please!!! #5
Steve,
Try this little unit conversion program - I find it really handy.
http://joshmadison.com/software/convert-for-windows/
Brad
I've been using that same program for quite a while now. But it didn't include the conversion for Nm to ft-lbs (or vice versa). I had to edit it in myself. Not a difficult edit, I just found it curious that the one I was specifically looking for at the time - was missing.
//greg//
/ translate please!!! #6
//greg//
That's odd Greg.
How long ago did you down load your version?
I too have been using the Josh Madison Convert Program for at least 5 years now. Mine had that conversion already in it under the "Torque" tab. You can see it in the photo below. That program has worked wonders for converting everything I've needed.
/ translate please!!! #7
Quite a few years ago actually. You could be right. Another thing I used the program for back then, was hydraulic lift capacity. Maybe it was Newton>lb-force. I don't actually recall which specific conversion I had to add, other than it included the metric Newton unit.
//greg//
//greg//
Thanks guys:)
I have all kinds of conversion information packed away somewhere. When I became part of a cost cutting effort last December after working about 40 years in the design/engineering field, they escorted us out of the plant, and had people pack up our offices.:mad::mad:
All my printed reference materials ended up in cardboard boxes. :eek:
All my electronic references remained on my company owned computer. I never had a chance to copy my shortcuts or favorites to maintain my links. I think I actually had this program on my work computer.
Thanks again.:D
/ translate please!!! #9
As a mechanical engineer I'd be embarrassed to say I worked in the engineering department and couldn't convert from Nm to ftlb.
/ translate please!!! #11
I just bought a new 3/8 drive inch pound torque wrench and it has Newton meters on one side and pounds on the other. My 1/2 inch foot pound drive is set up the same way. Maybe it's just the brand I use and most other wrenches aren't set up that way. Sure eliminates the conversion table. PJ
/ translate please!!! #12
usually on a qulity torque wrench
Thanks for the information. All my wrenches and torque wrenches got burned up in my barn fire, I had forgot what they looked like!
I just bought a new one and sure enough it is calibrated in M/KGS on one side and that is 10 Newton Meters:cool:
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
New - Front mount rototiller
New - Front mount...
2009 John Deere 1770NT Planter (A63111)
2009 John Deere...
Hitachi ZX75US Midi Excavator (A61572)
Hitachi ZX75US...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
