Backhoe trans problem
/ trans problem #1
jnw803
lefthand wv
ford 2120
I have a ford/nh 2120 12 speed f n r on left 1-2-3-4 on right..tractor will be pulling fine then all the sudden its like it kicks into neutral riv it up shift into different gear, go from high to med or low range nothing helps. After a little time it just starts pulling again. Dont matter if u move gears or anything or if u just sit and dont touch anything it will adventualy start pulling again....Any ideas...
/ trans problem #2
:welcome:
To the forum. Is that a 4x2 or 4x4 MFWD?
/ trans problem #4
I'm willing to bet your shift linkage bushings are worn out.
/ trans problem
Tractor is 1984 model, shuttle shift..
linkage bushings are good.. black box under steering wheel appears to b good. single wire going in top of it has 13 volts and both wires coming out of bottom of it has 13 volts.
/ trans problem #7
How many hours on it? Does the range lever feel like it's fully engaging the gears (mine doesn't always)? This is a gear shuttle, not hydraulic, right? I assume also the clutch is not disintegrating.
Jim
/ trans problem
It is gear shuttle, when it takes these spells I have tried switching from high to med to low range nothing happens. Clutch feels and sounds fine when it starts working again it will pull and everything clutch dont slip at all
/ trans problem #9
Well what is there that's not a hardened steel gear between engine and drive - the clutch, right? Some splines here and there?
Do you know the correct hours? Could this clutch have been abused some time in its history?
Maybe Rick B will weigh in - he da man.
Jim
/ trans problem
Not sure on hrs. I was told it has electrical selinoids that makes it go into forward and reverse. Ill check those next.
/ trans problem
Tractor is fixed....it was control box..little black box under steering wheel down at bottom ...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F-250...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2018 KOMATSU WA270-8 WHEEL LOADER (A65053)
2018 KOMATSU...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
