Trans/hydraulic fluud
/ Trans/hydraulic fluud #1
tractorcrazy
Do any of you guys use a different trans hydraulic fluid other than kubota. They say you have to use there udt oil .i would think other brands would if its labeled to meet spec's what's your all thoughts
/ Trans/hydraulic fluud #2
Under warranty = no way.
What machine are we talking here?
/ Trans/hydraulic fluud #3
I run mystic jt5 on my older kubotas used to use Napa Premium trans hydraulic fluid. Both meet kubota specs for UDT. I have a l2850 with a shuttle/clutch and a l4150 with hydraulic shuttle.
/ Trans/hydraulic fluud #4
I watched a couple of Messick's videos on after market oil filters and decided to stick with Kubota brand for all the filters:
/ Trans/hydraulic fluud #5
I use UDT-2. Not taking a risk once every 400 hours
/ Trans/hydraulic fluud #7
In my opinion, it is far more important to use the manufacturer sourced/spec'd. oil than it is to use the manufacturer sourced/spec'd. filter.
Even an old work sock could work as a filter!
/ Trans/hydraulic fluud #8
Most average users puts on 100 hours;so you are going to skimp every 2-1/2 years on oil and filters.I only use Kubota branded products.
/ Trans/hydraulic fluud #9
Only Kubota SUDT-2 oil here,..... but I do use Baldwin filters!
I have heard that Fleet Guard makes Kubota filters, but that may not mean much, as I am sure that whomever is the manufacturer of Kubota filters, they are made to Kubota spec's.
/ Trans/hydraulic fluud #10
As far as filters go, I've seen it go both ways, aftermarket bigger than Kubota, and Kubota bigger than aftermarket...it just depends on that particular tractor.
The latest oil filters for my Kubota powered Grasshopper, the Kubota filter has got quite a bit "shorter" than it was, and the price is way higher!
Personally, I'd rather have the older longer filter!
SR
/ Trans/hydraulic fluud #11
I have two gear drive ( NOT HST ) tractors. One 20 years old the other 10. I use Shell Rotella HD for tractor transmission fluid with a lot of winter use too. No problems. It's not the price. Rotella is available local.
gg
/ Trans/hydraulic fluud #12
gg
I use TSC Traveller oil in my two older gear gear drive tractors!
My Kubota HST gets Kubota SUDT-2 fluid.
/ Trans/hydraulic fluud #13
For my Kubota BX 25,. 2011 vintage; I have used NAPA 85-405 Hydraulic oil since it was new and now have 1500 hours and no problems. NAPA with my military/fleet discount is less than half the price of K SUDT-2. During times of heavy use I change every 200 hours. Buy 5 gallons at a time. Use cans for waste oil after. Also use all NAPA filters plus DELO 400 LE 15-40 lube oil. NAPA Filter #s: Fuel 3032, 6449 Air, 7088 Transmission, 1358 Engine.
Since moving from the tree ranch I am not using it much. The 1500 hours was accumulated over 6 years.
Ron
/ Trans/hydraulic fluud #14
Can I use another brand UDT because it's [choice] 1) less expensive, 2)my favorite, 3)available locally, 4)somebody else uses it .... has been discussed forever on this and other forums.
Please use the UDT prescribed by the OEM in the manual for the model. Please change the UDT at prescribed intervals.
If you're not inclined to do this then answer the following question, "Why am I risking the transmission & hydraulics pumps on my $7500/$15000/$25000 tractor to save $50/$100/$150 every 250/400 hours?"
2nd question. How come the gents that use different UDT don't post here about the new and additional noises their tractor makes when switching UDT?
3rd question. How much am I lowering the transmission & hydraulics system life span by using different UDT?
You can always take a sample and have it submitted for testing at your local Caterpillar dealer for Oil Analysis and the test results will tell you if the UDT really needs replacement. Last time I checked, the test was $25, so it's probably $40 now.
Example of Fluid testing pricing
/ Trans/hydraulic fluud #15
gg
TSC carries it as well, in 5's.
For a hydrostat, I'd only use SUDT. Don't have any here. Rotella HD flows very well in cold weather as well.
/ Trans/hydraulic fluud #16
To me, this seems to be the best argument.
And the hassle of having to deal with a major repair if it does fail.
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
2012 John Deere 1770NT CCS Planter (A63109)
2012 John Deere...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
Kubota Snow plow with subframe
Kubota Snow plow...
(2) 275/80R22.5 BF GOODRICH TIRES & ALUMINUM RIMS (A63745)
(2) 275/80R22.5 BF...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
