tranny warm-up time?
/ tranny warm-up time? #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
I know you're supposed to let a diesel warm up even in warm weather, but my question is reguarding the hydro tranny. When you are letting it warm, do you engage the high - low position or can you leave it in neutral and the tranny warms up (fluid circulates) anyway?
/ tranny warm-up time? #2
In <font color=red>cold<font color=red><font color=black> weather its better to let the tractor tranny warm up in neutral,also lower and raise 3 pt hitch plus fel 4 or 5 times after warm up time.
/ tranny warm-up time? #3
Leave the Hydro in neutral range and move the foot peddle/peddles back and forth as if you were operating the tractor.This will pump the oil through the hydro and warm it up also.
I don't do this much in warmer weather,but always in cool or cold temps.
/ tranny warm-up time? #4
i let mine warm up in netural, then when it is warmed up, in cold weather i cycle the fel and 3pt. a few times before i pull it out of the garage., then give it a another min or so warm up time.maybe over cautious, but better safe than sorry.
/ tranny warm-up time? #5
On a hydro driveline, as the range transmission is behind the hydro unit, you really can't do much to warm the mechanical side up, other than driving the tractor. As MReeter says, keeping the range in neutral, will get some movement going. I don't think that transmissions really need to be warmed up all that much though... Engines do because part dimensions are machined to deal with the expansion created by the heat of combustion... That's why a diesel engine tends to make so much noise at startup. (Hopefully), there is no combustion in your transmission.
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Hyster S50XL Forklift (A65579)
Hyster S50XL...
Auger Cart (A65640)
Auger Cart (A65640)
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
