Trails
/ Trails #1
Chiege
SE Ohio
MF GC 2300
Hello,
I am looking to make some trails through my woods for the purpose of jogging/walking. I have looked at some posts that have great info about how to cut and maintain trails for ATV's, Tractors, Trucks, etc... But how about jogging/walking?
Any runners/walkers out there? If so, do you do have any advice or suggestions for trails of this type?
/ Trails #2
Chiege, The past couple of weekends I have been working on a perimeter trail on my property. 95% of the brush is uprooted and moved out of the way with my FEL with teeth. Some big stubborn bushes need a little help with my backhoe. I make the trail at least 6 feet wide because that is the width of my rear tires and box blade. After The brush is removed I level and smooth it with my boxblade. I always carry a limb cutter with me and ever so often jump off the tractor and cut a few roots and limbs. You might think that 6' is too wide for a foot trail but walking two abreast is nice and it will soon grow in. The wider width also discourages spider webs. I use my golf cart and the 4' belly mower on my Farmall to maintain the trails.
Attached is a part of the trail that "Ys" off to a road. The trail looked like the brush in the middle.
This perimeter trail will be a 3.1 miles or 5K walk/run trail.
I have retired from the marathon runs after doing 15.
/ Trails #3
One more trail picture.
/ Trails #4
I long to move someplace that has some nice sandy ground like that; I'm so tired of CLAY...................
Ron
/ Trails #5
Trails are sorta a personal thing perhaps dictated by terrain, soil type and equipment available.
I have a small tractor that has been used for making a few trails. The bucket is used to make the trail and then the backblade is used for smoothing and grading. Mine are kept narrow - just the width of the implements used to maintain it. Encroaching branches are cut off. In general I try and make minimum impact on the surroundings following the easiest path I can but still going in the direction wanted. Forced into this as tractor is small and I dislike removing trees.
Note: Dead branches can fall from trees you hit with the tractor.
Trail pictured is going downhill on about a 10 degree slope.
Egon /forums/images/graemlins/grin.gif
/ Trails #6
I maintain hiking trails across my own, 2 neighbors to the right and 2 neighbors to the left and a couple neighbors up over a dam and back up the hill from the dam. Started off using nippers and a DR wheeled trimmer and hand-carried grass whip and chain saw. Then I graduated to a Gravely with 30" bush hog/mower, doing a swipe each way. Need a minimum of 5' width for even one person, to keep tall stuff from rubbing on you. When the tall stuff (wing stem) starts laying over, you need to enlarge to 6 and 7' in places.
Most places, all I had to do was to widen deer trails with trimmer/bush hog/nipper/chain saw. One trail ended up in a flood overflow zone; so, I moved uphill to an old maintenance trail constructed by the farmer who originally owned the land. Had to clear out a couple logs that had fallen and cut back a bunch of saplings with nippers and chain saw, helped with Roundup and Brush-Be-Gone. On my own property, the old farm house driveway ran through it. There were a couple trees that had fallen over that I had to cut and remove. Otherwise, when a tree falls, if it is easier to reroute around it, I do it. Did this when one fell near the creek but over onto my property. The trail now goes up and over the root area of the tree.
The neighbor 3rd one over had trails all over his property. His plus what I've done amount to 4 or 5 miles worth in, basically, the riparian area along a creek.
The trail up to the dam and back up the hill that way is maintained mainly with a grass whip and nippers. Too steep and rugged to get a tractor up that dam and then up the hill.
It's worth it. Chance of seeing anyone down there is less than 1% during the times I hike it. So, I do it nude most of the time.
Ralph
/ Trails #7
I made all my trails with a machete and chainsaw.It makes for some good exercise in itself.Once they are established the qauds keep them maintained for the most part,but in the spring there is always some thorns or something that needs to be wacked off that the machete takes care of.
Ditto on being sick of living with clay.
/ Trails #8
On our twenty acres I cut trails all through the woods by hand, that is with bush ax and sling blade. The swamp bottom that cuts across the middle keeps tractors off the back side, reluctance to cut trees restricts them over here. Just as well, I've been going for minimum impact. For high impact fun the Hunt Club and timber companies let me play on their place.
After two growing seasons of maintaining them with the sling blade I graduated to a DR Field and Brush mower, one of the old Bachtold Brothers models. It's still going strong after fourteen years. I've cut new trails and cleared most of the pond site with it. It would handle places that you couldn't walk through.
Here's a link to a few path pictures.
http://www.wimmark.com/path_pictures.htm
Wm
/ Trails #9
Thats what I want on my place, some nude hiking trails! I'm hoping my neighbors won't mind too much. They have easement rights to my road, but I'm thinking about putting up some "Caution Nude Hikers" signs. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
/ Trails #10
Come May be our guest. Hike at will sans clothing. There are a certain segment of living critters that will say " Thank You " as they don their bib's for meal time. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
/ Trails #11
I've built many miles of trails for mountain bicycling, very similar to hiking & running trails. Many trail runners prefer our trails to typical eastern hiking trails because they are usually laid out at lower grades. In relatively flat terrain, you can get by with trimming branches with loppers or a brush axe. Depending on how much traffic you expect, raking is a popular way to establish the trail tread. In steeper terrain, bench cutting is necessary to avoid creating off-camber trails.
Be sure not to build fall-line trails - trails should traverse across slopes and not go directly up or down them. The general rule is that water is the vehicle that erodes soil, so you have to keep it flowing off the trail. Grade reversals are an effective way to prevent water from flowing down a trail.
There's loads of information available at the International Mountain Bicycling Association's trail building page: http://www.imba.com/resources/trail_building/index.html .
IMBA's new book on how to build singletrack trails is perhaps the most comprehensive trail building manual available. I highly recommend it, see http://www.imba.com/resources/trail_building/trail_solutions.html
Rob
/ Trails #12
</font><font color="blue" class="small">( Thats what I want on my place, some nude hiking trails! I'm hoping my neighbors won't mind too much. They have easement rights to my road, but I'm thinking about putting up some "Caution Nude Hikers" signs. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif )</font>
Just be sure you eradicate all the poison ivy, first!
/ Trails #13
Here is what my trail in Colorado looks like; drainage, clay, etc. are NOT and issue.
Rocks & gravel are our "soil".
Hmmm. Maybe that's why they're called the Rocky Mountains! /forums/images/graemlins/grin.gif
/ Trails
That looks beautiful.
Wanna trade?
/ Trails #15
Enjoy looking at all the trails. Guess we can't have everything, moved away from the snow and -30 degrees, and lost most of the trees. My trail just goes around the fence line, just mow it short to keep the stickers off the path. Every thing that's green here, has thorns or needles.
With the constant threat of forest fires, seems to make sense to make the trails wide enough to be a fire break, and protect your trees. My first job was cutting fire trails in the National forests of VA. If a fire started it only burned the 20 sq arces.
They only need be a little wider than the tallest trees.
What did they say back then. (Keep Virgina Green) /forums/images/graemlins/smile.gif
Just a thought!
2017 Thompson 32HPU 55kW Towable Trash Pump (A59228)
2017 Thompson...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1994 Fontaine 45ft. 40 Ton T/A Flatbed Trailer (A59230)
1994 Fontaine...
