Trailering the Bota
/ Trailering the Bota #1
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
I'm looking at a trailer to make short moves with my L5450 and I'm figuring the weight rating needed. Basic tractor is 4400, loader is maybe 1300, backhoe is 1800, so 7500 plus ballast. Does anyone know how much weight of calcium chloride solution can be added to 17.5 X 24 R-4's ? Anybody know of a listing by tire size?
I've got a Silverado 4wd - am I nuts? (wife says yes)
/ Trailering the Bota #2
In my opinion, you should be looking for at least a 10,000 GVWR trailer; tandem axle with brakes.
<font color=blue>I've got a Silverado 4wd - am I nuts? (wife says yes)</font color=blue>
It depends on the tow rating of that particular vehicle, which includes such things as engine size, transmission, differential ratio, heavy duty cooling, brakes, etc. If it's a half ton (and I'm assuming it is), then you'll probably be pushing it's limits a bit.
Bird
/ Trailering the Bota #3
I have a 2910 w/FEL, MM mower, and box blade on a 1640# trailer rated at 7000# GVW. I am pulling this with a 3/4 ton 4WD Silverado w/ a 350 V-8 & auto trans. I feel that with this weight I am about at the limit of the trucks capabilities. I'm sure I could pull more, but my gas mileage goes down to the 10-12 range pulling this, and I can feel the strain on the engine. If you are going to pull that much weight, I would recommend a 1 ton chassis, with a diesel or big block V-8, and towing package. Your truck will last a lot longer if it doesn't have to strain so much. In my humble opinion.
Joe W.
/ Trailering the Bota #4
I would go with what Bird said, but get a goose-neck. Also get electric brakes on both axles. I personally would not worry bout the truck being a little over capacity. Then again Iam the guy that pulls a 450 dozer and 580 bachoe with a HD3/4ton. Usaully one or the other
/ Trailering the Bota #5
rbargeron,
I have a one ton good for a 10000 lbs trailer load. I don't like pushing the truck to its limits for long hauls so I try to stay under 70% of its max. By my rule a standard tag along landscape trailer at 7000 gvw works fine. I have the tow package and added an extra oil filter and large capacity tranny pan. I would argee if you want 10000 lb trailer a gooseneck would be the way to go it puts the weight directly on the rear tires instead of behind them. This reduces sway, turning radius, and looks cool. I would also make sure you have a good set of brakes on the trialer and a good controller.
just my two cents
/ Trailering the Bota #6
I would have to second the motions for gooseneck trailer, at least a 3/4 ton, good brakes on truck and trailer, and at least a 10k trailer. With that said you could probably get by with a half ton pickup, but not the best situation. You could also get by pretty good with just a bumper pull trailer as well. I don't think that's a big issue but something to consider. If cost is an issue go for bumper pull and you won't have a problem if you have a 10k trailer, just a little easier and safer with gooseneck. The two things you can't do without though are a 10k rated trailer and excellent brakes on the trailer and brake controller on the pickup.
/ Trailering the Bota #7
If the truck is a 3/4 ton, you might do it. Most 3/4 ton HD trucks are GVWR of 8800 lbs or so.
You're really looking more realistically at a 1-ton...
One thing I've always found, is it really sucks to be under-trucked. Only happened once, and I didn't like it.
The thing you might look at, is trying to keep at ~80% of your trucks limit. If there is a emergency stop or swerve, you don't want to pushing the truck or trailers limit.
RobertN in Shingle Springs Calif
/ Trailering the Bota #8
rbargeron
ref. the load weight of your size tires I saw that (I think) in a section at tractorsmart.com. I don't have their url, I followed a link from somewhere/w3tcompact/icons/crazy.gif
regards
Mutt
p.s. I forgot how to spell that disease that the older generation gets/w3tcompact/icons/wink.gif
Lots of good advice - it's a great reality check.
A tandem-axle trailer (7k gvw with zoot brakes & controller) is available for low money so I was wondering about its feasibility. But it really isn't enough trailer - and my stovebolt is only a 1500 so it isn't enough truck either.
Maybe I've got too much tractor. Nah, there's no such thing.
I'll keep my eyes open for a 1-ton and 10k trailer. Or maybe just keep my projects in the neighborhood.
Thanks to all.
Dick Bargeron
hey mutt - you da man! 3 clicks and I was looking at the chart of water weight by tire size. Thanks !
/ Trailering the Bota #11
Lots of good advice... Now all you guys have me missing my gooseneck... Once you use one it is hard to go back to a bumper pull for any kind of load....
/ Trailering the Bota #12
If you can't go with a goose neck (the best way) I would use a weight distribution hitch for a bumper pull. Using a half ton would be o.k. for short trips, slower speeds, and gear down the truck a lot when in hills. But if you tow it on a regular basis you will need a HD 3/4 or one ton.
Derek
So what did I do? I told another guy about the 7k trailer and he decided to buy it ! He's a friend so I offered to put in a third of the money if I can use it once in a while. It comes with a pintle hitch for 2" receiver (which I have), and a pretty zoot controller for the brakes (which we'll put in his Ford). I'll get one for my Chivvy.
So I guess that despite all the sound advice against it, I'll see if the Silverado's tranny will let any of its smoke out.
I'll probably only move my tractor once in a while - and not far. I'll post the results - from the hospital or jail.
/ Trailering the Bota #14
Put the truck on the trailer and pull the trailer with the tractor!
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
HD Bale Ring (A66408)
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
New Holland 451 Sickle Bar Mower (A66408)
New Holland 451...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
