Trailering a JD990 and MX5 cutter
   / Trailering a JD990 and MX5 cutter #1
JDNineNinety
Hernando, Ms. 38632
John Deere 990 2-wheel drive
I have a jd990 with a jdmx5 cutter. I want to buy a trailer
to transport it. I have a 2003 Ford Ranger 4-wheel drive
with the FX4 off-road package. The 990 2-wheel weighs
3000 lbs. and the mx5 weighs 800 lbs. Will the trailer
push me over my 5200 lb. limit? Anyone help?
   / Trailering a JD990 and MX5 cutter #2
My 16' trailer weighs 1600 pounds.
You may get away with overloading by a couple hundreds pounds if your area is fairly flat.
Make sure your trailer has brakes that work.
Thanks for the info. I failed to mention that my tractor and hog are 19-ft in
length. Also my max loaded trailer weight is 5560 lbs.
I looked at the Big Tex Trailer site but they don't give
weights.
   / Trailering a JD990 and MX5 cutter #4
The Ranger 4x4's were build on a ¾ ton chassis so I think the truck can handle it. Not sure about the engine or transmission though...especially the transmission. If it's a stick and you stick with direct drive (no 5th gear usage), I'd try it. If you have an automatic, I think I'd want a transmission oil cooler.
Definitely a hitch welded to the frame...the bumper type hitch wouldn't hack it.
After that, it's technique... That Ranger doesn't have the mass of a larger truck...it'll be easier for the "tail to wag the dog" if you're not careful. Even on the highways, you'll want to limit your speed to around 50 MPH. Hills and such will require the use of lower gears. And your stoppong distances will be greatly extended.
Roy, I have the 4.0 liter V-6 with 4.10 gears with the
5-speed auto with overdrive cutoff switch. I also have
the factory receiver hitch. My factory max weight is 5560.
I would want electric brakes on both axles. Thank you
for the info.
Roy, I forgot to mention I have the transmission oil cooler.
   / Trailering a JD990 and MX5 cutter #7
I tow my tractor with a Chevy Astro Van AWD.
Not a bad tow with equalizer load leveling hitch and 4 wheel brakes.
We have small hills but nothing that the Astro cannot handle.
My loaded trailer is closer to 4000 pounds.
Your Ranger may be under powered and overloaded with a load over 5500 pounds.
   / Trailering a JD990 and MX5 cutter #8
<font color="blue">My factory max weight is 5560. </font>
The Ford site says that a Ranger with FX4 Level 2 option is rated at 5200 pounds.
Is that the same package you have?
   / Trailering a JD990 and MX5 cutter #9
I think you'll be over the limit trying to haul both because of trailer length. My 7X18' 10k weighs 2,500lbs. I wouldn't think a 7k trailer would be that much less. Most 6x16' weigh 1500lbs or more. You could tow it without cutter on 16' or buy another truck. I lean toward the new truck.
I have the FX4 Level 1. I have a Ford Trailering brochure
that says my max weight is 5560.
2025 LandHonor LHR-WS22 Webbing Slings (A49462)
2025 LandHonor...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
INGERSOLL RAND DD-16 SMOOTH DOUBLE DRUM ROLLER (A51242)
INGERSOLL RAND...
