Trailer???
/ Trailer??? #21
Just found out that the axles have not been cut. Owner will check hub backing plate tomorrow. One thing that I noticed was that on the front of the frame you can see where an manufacturer ID tag was attached. It was not on it so I don't understand why it was not there. The rivets were still on the frame. The trailer has the build quality of a factory made unit.
In my area when I find a trailer where the VIN tag has been removed its usually because it is stolen. No other reason I can think of to remove it.
/ Trailer??? #22
+1
"Too good to be true" usually reeks of trouble. If the DMV has suspicion that VIN had been altered or removed they will not title it.
Sent from my iPhone 2.0 using TractorByNet
/ Trailer??? #23
VIN tag removed = previously stolen. They don't fall off. Deal breaker for me. Sorry to be negative! I don't usually weigh in on "should I ..." threads but this just has a lot of red flags.
/ Trailer???
Thanks for the heads up guys...
I thought about that initially...
I questioned the gentleman selling it and he told me it was that way when bought it in South Carolina...
He is a local guy and not a dealer which really means nothing in the grand scheme of things...
If he was trying to be shady looks like he would have removed the place where the ID was located, ground off the rivets, and repainted...
I am confident that the trailer is just as he purchased...
If it was stolen I believe that the tag was removed prior to his purchase...
The trailer is located at his home and I think that he may have been a bit naive about buying it initially...
That is my opinion and nothing more or less...
/ Trailer??? #25
That is what I was thinking Chris. I asked him if they were MH axles or trailer type and he did not know for sure. What type of ID would I look for on the axle to show that is a trailer axle? I had that exact number in mind Chris and we got really close to it. I''m going to give him a call tonight to confirm the axle type.
Only way I know is to take apart a Hun and look at the bearings and brakes to be sure. If you are lucky you may find a marking on the axle itself by crawling under it.
Chris
/ Trailer??? #26
Now I guess I can't say for sure, but am I the only one to whom that just does not look anything like a mobile home frame?
/ Trailer??? #27
I was thinking the same thing Bird. Can't come up with a reason why someone would build a frame like that and then put MH axles under it. My trailer doesn't have a tag on it but it was damaged and rebuilt by a trailer shop, where I bought it. It looks rough but I checked it and it has Dexter axles. My guess is there is some ID on the axles.
/ Trailer???
Thanks Chris for the info. The owner is going to check out the hubs for me later and report back.
Bird and KennyG: I am like you. Can't understand someone building that heavy of a trailer and then using mobile home axles.
If you look at one of the pictures you can see where a manufacturers tag was affixed at one time. The things I am asking the owner about he was not really aware of. We discussed how it looks like a factory made trailer but then some things like the pintle hitch not being adjustable don't make sense. Hopefully by this weekend I will know for sure the axle type. Again I think the he is being upfront with me. I just don't think that he was aware of some of the issues that I am asking.
/ Trailer??? #29
I don't know if this helps you, Both of my trailers were built by different companies. Both have MFG tags with VIN # and they also have the VIN stamped in the frame.
/ Trailer???
Thanks Topbuilder for the info...
The owner told me that the hub backing plate was bolted on and not welded...
What I expected...
I am going up Saturday with the truck and will look at the axles underneath for some type of identification...
I got him down on price another $100 so I think it is a good opportunity...
I know a State Trooper and I can get him to do the inspection...
I will update after Saturday...
Thanks to everyone for their help and input...
I really appreciate it...
/ Trailer??? #31
Here in the Southeast, a lot of trailers have that type axle/wheels that are not MH. We generally call them low boy tires, used a lot on equipment trailers.14.5" tires, just a little lower than 16-18". Can't use MH tires, both because they aren't the best, but really because the tax is different on them. It just looks like a fairly heavy duty equipment trailer to me, but need to look under neath to make sure.
/ Trailer??? #32
Looks like a standard tri axle equipment trailer sold by a lot of companies. Dayton type axles were very popular for heavy duty low pro trailers. My eager beaver dump built in '88 has them as does my dad's '91 Hurst single axle utility. Both have been good trailers and hauled more then they should at one time.
Price on that trailer seems decent based on what I've seen selling around here.
/ Trailer???
Yes TMGT that is a more than fair price. It is really more trailer than I need but if I get a backhoe or small excavator it would handle it. My Chevy 2500 HD is really not enough truck if loaded to 18K total but with my current tractors and bush hog I will be in the 11K range. Truck should be OK.
/ Trailer??? #34
Around here you see those trailers with one of the axles removed a lot of times, makes a nice heavy trailer that's less expensive and makes turning a lot easier, as long as you don't need the extra capacity.
I pull my dump trailer with a 5ton load behind my 07 Ram 2500, no problems, I have air bags on the trucks rear axle and makes a huge improvement.
/ Trailer???
That is a great thought TMGT. That would lower the unit to 12K total with a capacity around 9K. I'll have to give that some thought.
First order of business is to get it titled and upgrade my Class C commercial license to Class A CDL. I need to take the air brake written test and road test.
Back when I was 16 you could get your Class A commercial license by just paying more. I did that but when the new regulations came into effect I didn't update my license. All I would have needed to do was take the written test to be grandfathered. My dad did that and he still has his CDL's at 85. We just admitted him to a nursing facility for rehab so I doubt he will ever use them again.
/ Trailer??? #36
Do any of your trucks have air brakes? Otherwise no need, I have a class A but no air brake endorsement at the moment.
/ Trailer???
Actually no. I would need it if I was going to use a truck with them. I will double check with the DMV. I may just need to pony up more for the license.
/ Trailer??? #38
Are there any class A required trucks that don't have air brakes?
And does anyone know why air brakes are such a concern for licensing?
/ Trailer??? #39
Sounds as if you might be nearly as old as I am.:laughing: I got the standard drivers license in Oklahoma when I was 16, but later that year, we moved to Texas and I had to take both written and driving test to get my Texas Operator's License. A year or so later, when I started occasionally driving a 12 wheeler (tractor trailer grain hauler) I only had to take a written test to get my Commercial Operator's License. Then when I was 19, working nights at the post office, and driving a taxi cab part time, I had to take another written test to get my Chauffeur's License, and I also drove a school bus one year. I was 29, and a police sergeant, when Texas invented a separate endorsement for motorcycles and I had a little 350 cc Yamaha at the time, so another written and driving test for the motorcycle license.:laughing:
/ Trailer??? #40
Yes, I use to drive one, that's part of the reason I didn't get it. That and I didn't have access to a truck with airbrakes when I took the road test.
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
