Trailer?
/ Trailer? #41
wroughn harv - your advice is right on! I built an 18' tandem axle trailer last year to haul my tractor. I ordered the axles for it with Ford 8 lug spindles to match my truck. As luck would have it, the first time I used it, I had a flat on the trailer, and I had to use my truck spare. I was mighty glad I took my Dad's advice and ordered the axles to match my truck...
Corm
/ Trailer? #42
<font color=blue>We've got plenty of RV manufacturers just north of here </font color=blue>
I must have had a blonde moment and forgot you're not far from me Gary. There is a great RV surplus/salvage place in Elkhart. They may have something reasonably priced. Let me know if you want the particulars.
We've got electric jacks on our fifth wheel and you could probably rig up something like that as well. Two jacks would be more stable and have more capacity /w3tcompact/icons/smile.gif
/ Trailer? #43
Mine has a jack in the tongue V that is for a semi trailer. It is very easy to turn up, so easy infact that you have to watch it to make sure you're not jacking it up instead of letting it down. Very little difference in labor.
/ Trailer? #44
Hey, Rob. We went over to Elkhart last week looking at trailers. There is a place on 19 just south of CR6 that had hundreds of trailers. Looked pretty nice. Now I can't decide between the car hauler or landscaper types.
Car hauler would be better if I wanted to haul some dirt, since it has a solid floor. I could also weld on some sides if I needed.
On the other hand, landscaper already has sides, but wood plank floor. I could lay down plywood if I needed to haul dirt.
Both about the same price. Both with the same 3500# axles. Now I'm just gonna wait a week, then go back and take a second look.
/ Trailer? #45
There should be a third option......a custom built. He should be able to give you precisely what you want with the options from both types that you want. I had mine built like that and he even took the paint numbers off my truck and painted it to match. It was delivered 14 days after I ordered it.
Just tell him you want the car hauler with sides from the landscape trailer or the landscape trailer with a solid floor.
/ Trailer? #46
MossRoad:
If you go for the car hauler with stake pockets. You can always add your own sides later. This gives you the advantage of being able to remove them at your conveince, if you want to side load / unload palletized or awkward loads.
/ Trailer? #47
David, you must me talking about MSI in Elkhart. I looked there and almost bought but ended up getting a much nicer trailer for a little more money at Tuff Top on Bristol. I got a car hauler with stake pockets and rub-rail. As someone else mentioned, you can always add sides with the stake pockets and I'm finding it handy to have no sides to deal with for general use. You're welcome to have a look at my trailer any time you want /w3tcompact/icons/smile.gif
Almost forgot... a buddy here at work has 14 or 16 foot landscape trailer for sale. I can get some details on that if you are interested.
/ Trailer? #48
has anybody looked into getting a dump trailer? I used to have an old dodge dually dump and I miss it sometimes. However I dont miss the ride /w3tcompact/icons/smile.gif . I bought a F350 superduty and it rides like a car. Anyway I'm not going to go to the gravel yard and let the operator dump gravel in and down the sides of the new truck bed. So I thought about getting a pull behind dump trailer. Then I thought why not get one that my 2910 can go in if I need to transport it. I should have plenty of towing capacity (F350 w/V10). Looking for pros and cons to this line of thinking. Also if anyone has any experience with these types of trailers (brands, worthwhile features to look for , etc) Thanks in advance guys
/ Trailer? #49
Paul, I think a dump trailer would be real handy to have. The ones I've seen have the bed over the wheels so it's pretty high. Not sure I'd want my tractor (and it's center of gravity) up that high driving down the road /w3tcompact/icons/smile.gif
/ Trailer? #50
Paul in CT - go the the "Attachments" and look for thread that started on 3/3/02 on "Dump Trailers". We beat the subject to death.
/ Trailer? #51
td, get a 17' trailer , tand. axle. I got a 755 with loader, and when you put something on 3ph, you will use up all that room. Thats the setup I got. make sure you get trailer brakes with that little truck of yours. You tractor is only 1 size biugger than mine, but doesnt really weigh that much more. Trust me.,.....17' will fit that tractor. And will be around when you upgrade your truck. You can also haul gravel/sand/mulch/dirt etc with side rails.
/ Trailer? #52
Haven't heard anyone mention the use of load leveler or stabilizer arms, that appear to be commonly used on camper trailers. We started using these when I was a kid, on the camper, and I would think they would be great for any sort of heavy trailer. I've seen many rigs around here, sagging in the back, even though they we not overloaded. That kills steering, handling, and braking in the front.
For those who don't know (maybe some one could put up a pic or better explanation), the stabilizers are usually slender solid steel pieces about 1" or so square, about 30" or so long. They bridge between either side of the receiver hitch (you need a special hitch with the "sockets" to accept the stabilizers), and back to the trailer tongue frame on each side, where they are tensioned in the same way a chain binder is. The solid mounting at the receiver, and upward tension back along the tongue, forces the tongue/hitch/truck frame up into alignment, and puts more load on the front axle. I'm told it's possible to put enough force on the stabilizers that you can actually reduce rear traction, if the ball is too low to start with.
Once properly adjusted for the truck/trailer, they are very easy to put on and pull up. Can anyone give more detail on these, and possibly any problems or concerns? I'd think a lighter truck, like the Toyota, would benefit greatly from them.
/ Trailer? #53
My dad has a sway control hitch system by Reese. Their website offers some good info
<A target="_blank" HREF=http://www.reeseprod.com/>http://www.reeseprod.com/</A>
/ Trailer?
Thanks woody,
I am searching as we speak. I am ready to take my tractor show on the road.
/ Trailer? #55
Thanks, gobbler
<A target="_blank" HREF=http://www.reeseprod.com/info/info/img/wd_info_callouts.gif>Here's</A> the specific system I was talking about. I'm gonna put one on my trailer (when I get it).
/ Trailer? #57
Reese, I think, used to advertize equalizer hitches by pulling a trailer around to shows behind an Olds Toronado. The Toro didn't have rear wheels and tires, the trailer, through the hitch, carried the rear of the car.
/ Trailer? #58
Mark,
Good point. I have used the reese system with a 23 foot wilderness camper and the difference is amazing in terms of how the trailer handles behind the tow vehicle. I now tow with a Suburban and the hitch indicates a greater towing capacity with a "equalizer hitch". I'm not positive but I believe there is about 30 % more towing capacity. I have not used it with my 16 foot tandem axel trailer that I tow my tractor with as I didn't feel it was necessary. My calculated weight with trailer,tractor and loader is less than 5000 lbs. It definetly makse a positive difference.
/ Trailer? #59
I noticed a jeep GC pulling a tractor! Can I do that with my cherokee? How can I figure out the tongue weight and how much it will hold or pull? Whenever people talk about weight and traveling why is it allways hyrogliphics to me?
/ Trailer? #60
The Jeep Operators Manual should have that information in it.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
UNUSED WOLVERINE 7' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
(5) FOSTER 10' X 20' STEEL MATS (A64276)
(5) FOSTER 10' X...
