Trailer WHEELS
   / Trailer WHEELS #1
Robert NC
Charlotte, NC
I have a trailer with 14.5, 6x5.5 bolt patter and 3.5 center hole. Trying to figure out what truck wheels either 15 or 16 in would fit these axles. Alot easier to find 15 or 16 inch tires. Any help would be appreciated.
Robert
   / Trailer WHEELS #2
Do you need truck wheels for a particular reason? The offset on truck wheels is usually different than trailer wheels....sometimes creating problems with fenders etc.
   / Trailer WHEELS
I figured that it would be easier to get a set of used truck wheels from a junk yard than any other kind. Fenders are no problem as ait doesn't have have any at this time.
   / Trailer WHEELS #4
Any RV place should be able to get you the 14.5 inch tires, but your looking at about $100 each.. sounds like an equipment trailer, them 14.5 are probably 12 ply tires..
   / Trailer WHEELS #5
There is a tire dealer about 10 miles from my house and he had 14.5, 12 ply tires new for 20 bucks each and mounted it for me for a couple more. I'de advise checking for a back country truck tire dealer, might save you a bunch of problems.
   / Trailer WHEELS
Should have said that trailer axles are Mobile home axles. Older and real heavy duty hubs. Solid center wheels one piece not two piece. That is the reason I was wanting to get away from 14.5 wheels. Just got trailer and price was ony $60.00. Will be using to occassionally haul my 660 with blade or disk. Also gravel, dirt, mulch, etc. Didn't want to have to get new 15/16 trailer wheels. Thought junkyard if I can figure out the brand wheel.
Robert
   / Trailer WHEELS #10
I just bought a trailer with 14.5 inch demountable wheels. The tire size is 8x14.5. So you are telling me that with these old school RV hubs I can remove my demountable 14.5 inch wheels and bolt up a set of Chevy or Jeep 5x5.5 or 6x5.5 truck wheels wihtout having to change the whole hub assembly and then actually be able to select from a normal array of tires of radial tires ???
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
