Trailer WHEELS
/ Trailer WHEELS #1
Robert NC
Charlotte, NC
I have a trailer with 14.5, 6x5.5 bolt patter and 3.5 center hole. Trying to figure out what truck wheels either 15 or 16 in would fit these axles. Alot easier to find 15 or 16 inch tires. Any help would be appreciated.
Robert
/ Trailer WHEELS #2
Do you need truck wheels for a particular reason? The offset on truck wheels is usually different than trailer wheels....sometimes creating problems with fenders etc.
/ Trailer WHEELS
I figured that it would be easier to get a set of used truck wheels from a junk yard than any other kind. Fenders are no problem as ait doesn't have have any at this time.
/ Trailer WHEELS #4
Any RV place should be able to get you the 14.5 inch tires, but your looking at about $100 each.. sounds like an equipment trailer, them 14.5 are probably 12 ply tires..
/ Trailer WHEELS #5
There is a tire dealer about 10 miles from my house and he had 14.5, 12 ply tires new for 20 bucks each and mounted it for me for a couple more. I'de advise checking for a back country truck tire dealer, might save you a bunch of problems.
/ Trailer WHEELS
Should have said that trailer axles are Mobile home axles. Older and real heavy duty hubs. Solid center wheels one piece not two piece. That is the reason I was wanting to get away from 14.5 wheels. Just got trailer and price was ony $60.00. Will be using to occassionally haul my 660 with blade or disk. Also gravel, dirt, mulch, etc. Didn't want to have to get new 15/16 trailer wheels. Thought junkyard if I can figure out the brand wheel.
Robert
/ Trailer WHEELS #10
I just bought a trailer with 14.5 inch demountable wheels. The tire size is 8x14.5. So you are telling me that with these old school RV hubs I can remove my demountable 14.5 inch wheels and bolt up a set of Chevy or Jeep 5x5.5 or 6x5.5 truck wheels wihtout having to change the whole hub assembly and then actually be able to select from a normal array of tires of radial tires ???
/ Trailer WHEELS
Depends. Checked and double checed. Mine has the 6 x 5.5 with a 3.5 bore hole. Check the site that Shutt40 indicated. You will find that the 100mm wheels are what will fit, but the center is 12 mm larger than the hub I have. Chevy hubs are 78mm I believe. Toyota and Nissan both sold 6 x 5.5 14 and 15 inch trucks. The wheels center on the lugs or so I been told. I haven' bought wheels yet. Tractor went down and got to fix it first. If the tractor don't work, don't need a trailer.
Robert
/ Trailer WHEELS #13
Do you want to sell your old rims... I am looking for a full set of 14.5 rims with a 6 bolt pattern. If you know where a guy can get them... thanks guys
/ Trailer WHEELS #14
Sometimes you can change wheelbolt patterns just by changing the wheel portion of your hubs, leaving the original spindles on the axle. With many small boat trailers you can replace the 4 bolt hubs with 5 bolt units, then go to 14/15" chevy rims. Doesn't increase your axle weight rating but does give a smoother ride and more ground clearance, especially on rough ground.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2022 EZ-GO ELITE...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
