Trailer WHEELS
   / Trailer WHEELS
Depends. Checked and double checed. Mine has the 6 x 5.5 with a 3.5 bore hole. Check the site that Shutt40 indicated. You will find that the 100mm wheels are what will fit, but the center is 12 mm larger than the hub I have. Chevy hubs are 78mm I believe. Toyota and Nissan both sold 6 x 5.5 14 and 15 inch trucks. The wheels center on the lugs or so I been told. I haven' bought wheels yet. Tractor went down and got to fix it first. If the tractor don't work, don't need a trailer.
Robert
   / Trailer WHEELS #13
Do you want to sell your old rims... I am looking for a full set of 14.5 rims with a 6 bolt pattern. If you know where a guy can get them... thanks guys
   / Trailer WHEELS #14
Sometimes you can change wheelbolt patterns just by changing the wheel portion of your hubs, leaving the original spindles on the axle. With many small boat trailers you can replace the 4 bolt hubs with 5 bolt units, then go to 14/15" chevy rims. Doesn't increase your axle weight rating but does give a smoother ride and more ground clearance, especially on rough ground.
Entyre Chip Spreader (A57453)
Entyre Chip...
INGERSOLL RAND SD25F PADFOOT ROLLER (A52709)
INGERSOLL RAND...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
